Oil in transmission in d15
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: Oil in transmission in d15
    Posted: 29 Jun 2020 at 7:25am
What is everyone using for oil in the transmission?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2020 at 8:36am
Farm and Fleet Universal transdraulic fluid.
Meanolallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meanolallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 9:10pm
I like 80w-90. It seems to make the gears run quieter and probably longer. I think it also makes it easier to shift without grinding because the gears stop spinning a little quicker after you push in the clutch.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2020 at 9:26pm
Universal hyd. 80-90 won't lube bearings in cold weather near as good.        MACK
