Hydraulic pump
Chad190xt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad190xt Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic pump
    Posted: 22 May 2020 at 8:07pm
Looking for help , I have a 190xt that I put in shop over 6 months ago to redo, I pulled the oil cooler off and replaced lines from cooler to pump, never removed the pump, I changed the filter , cleaned sump screen , changed oil, so now with that all being done , it’s very choppy to steer and the pump makes a squealing noise, I was told my pump is going bad , I have also pulled the plunger out of pump and that’s not sticking , looking to not buy a pump at 2 grand maybe there is something I’m over looking any help would be greatly appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:42am
Moved to Farm Equipment page from 'Forum Support Page'
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 3:59pm
If the power steering worked fine before you worked on the tractor, then it would be logical to think if it doesn't work correctly now, you have changed something or done something wrong. The pump shouldn't have broken just sitting in the shop. Low on hydraulic oil ??  Crossed lines ?? An air leak between the suction tube and rubber connections at each end ??
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 4:15pm
It is also possible you have not worked all the air out of the system.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 4:27pm
Did you jack the front end up and work the steering back and forth to get the air out? Like the good Dr said you sure everything is tight and not sucking air?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad190xt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 8:28pm
ok so I jacked up the front end I was able to steer it back and forth , when I put the PD in either high or low it would fight me to turn it, so when I put weight on steer tires it also turned very hard , and I know all my connections are correct and I’ve bled every line possible , I’m stumped and irritated
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 10:14pm
I would say you have the two lines switched on back of pump.     MACK
This page was generated in 0.189 seconds.
