Sway blocks
Andy NW Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy NW Iowa Quote  Post ReplyReply Direct Link To This Post Topic: Sway blocks
    Posted: 09 Jan 2012 at 8:11am
I bought these sway blocks on a farm sale and I'm wondering what tractor/s they come off of? Any educated guesses? The first one has a casting number of AM 5548 and also a FM is stamped under that. The second one has a casting number of AM 5382-1 and RH is stamped under that
Top view of the first one
And the bottom,
Top of the 2nd one notice the tab at the left of the picture
and the bottom
One or both of these could have come from a 210 or 220, but I have no way to cross the casting number I'd like to know a tractor they come from or a part number that the casting number crosses to.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 10:43am
The top one is what I have on my D17IV and should be the same as 170-185.
The bottom one looks to me like a 210-220?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy NW Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 11:13am
thanks Travis, Did you buy a sway block on ebay last week, because I sent one to Seward NE on Saturday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 12:25pm
That would be me! Good to know my funds are going to another orange fan of this site.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:59pm
The bottom one will work for a D21 210 AND 220 Niel
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:10pm
Sorry, to ask such a silly question, however what do you use a "sway block" for??  I've been around A-C for over 20 years and never heard this term.  Thanks for any assistance and apologize for my ignorance.  Going orange is going great!
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:21pm
Sway block are mounted on the inside of the lower 3 point arms to keep them from swaying back and forth or take the clearance away on how far the 3 point can move from side to side when hooked up to a 3 point implement.  Some blocks mount on the arms or the drawbar hitch housing sides or both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:36pm
The painted orange piece is a sway block in use on a series IV factory 3pt.
The one in the picture should be the same as the very top picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 9:51pm
Learn something new everyday and I really appreciate you going the extra mile to post the picture and show me.  As usual a picture is worth a 1000 words.  You're a good man Travis.
Thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy NW Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 4:23pm
Thanks every body, I plan on posting these on Ebay next week, I also have a different set on  now, differnt casting number, and a factory 3rd arm.  Thanks
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2012 at 5:05pm
Travis, isn't that a little overkill on the drink holder?  Oh, I see now, it's a cover for the hitch ball!  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 6:55am
Used to be a Shallower block for Cat 1 attachments as on my 180, does anyone still repro those? Would seriously consider a buy of those. No blocks is WAY too loose, cat 2 blocks can be too wide and have to be pulled then back to wide swinging.
Edited by DMiller - 27 May 2020 at 6:55am
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 1:30pm
Here is info from an earlier post: Wagner AG sales out of Doniphan NE phone #402-744-3831.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2020 at 6:48am
For whatever reason, Cat 1 sway blocks are not easy to find.  All the new ones you can find on EBay are the Cat 2 ones.  I use mostly Cat 1 implements on our D17 IV with factory 3 ph.  I found one Cat 1 sway block years ago, then finally found another one last Oct, so it only took me probably 3 years to finally get both.
Before I found this one, I had cut a block of hardwood out, which held up quite well for mowers and such.  I had thought of just fabricating one from steel, or cutting off the excess steel on the Cat 2 ones readily available.  EBay does seem to have them come up once in a while, but they are not easy to find for sure.
