185 rops with roof
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 185 rops with roof
    Posted: 25 May 2020 at 10:16pm
Hello all.
Question. IV seen pictures of 185 tractors with rops that slant back with a roof. Were those rated for roll over. And we're they factory. And are the easily installed.
Thanks
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2020 at 10:25pm
Factory yes. Roll over, ?. Easy to put on, NO.        MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:18am
If it's factory they are ROPS. (Rollover Protection Structure)
Wink
I am a Russian Bot
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:44am
Factory had additional bracing under the tractor....the roofs are quite nice if you are 5 foot tall...without the seatbelt they are not very safe...
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:06am
Here is a test on a 190 with ROPS!
https://www.youtube.com/results?search_query=tractor+rops+test
ROPS are designed for protection and requires seatbelt usage for protection as you could be pinned if trying to jump with protection around you.
The owners manual has installation instructions including bolt sizing and hardness, torque etc.
If you wear a seatbelt on an open platform you could be in danger by not being able to jump clear.
I have a 185 with ROPS and Canopy. Canopies are more difficult to find, built heavy and make excellent shade.
----I am looking for an additional Canopy for another ROPS install.
Edited by JoeO(CMO) - 26 May 2020 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:11am
After you cut openings in the fenders, you'll throw up at what they look like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:19am
I used spacers cut to length of thickness of side bars and put the fenders on outside of bars, ,, ,lose the innermost wheel tread spacing.
Edited by JoeO(CMO) - 26 May 2020 at 9:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:28am
Joe do you have pictures of yours. I just thought if we were to put some sort of umbrella or canopy, use the factory looking one.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 11:27am
I've always thought - couldn't they have changed the width just a little instead of cutting holes in the fenders!? That's just screwed up
Edited by DougG - 26 May 2020 at 11:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 11:59am
They wanted to still be able to get to 60 inch wheel tread.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 12:04pm
Yes Allis offered the ROPS with canopy. And be sure you get the underneath brackets that hold everything together!
General Backhoe Service manufactures the ROPS and canopy off the A-C Design. Based out of Milwaukee, WI, call 414-651-9017. Canopy can be purchased separately.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 6:55am
Joe do you have pictures of your fenders spaced out. Thanks
This page was generated in 0.152 seconds.
