Wd45 oil pressure
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 oil pressure
    Posted: 20 Apr 2012 at 11:34pm
My wd45 has little to no oil pressure what could this be? My tractor hadn't had th oil changed before i got it and was filled with sludge could this be part of it?
Mark G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark G. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 5:06am
Your oil pressure line that runs to the gauge could be pluged with sludge
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 6:59am
Normal for a WD45 to have low oil pressure. 7LBs at max.   MACK
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 7:07am
Dose it have the correct oil pressure gauge?  Also some oil filters do not provide enough resriction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 7:10am
Check with a 30psi max, known good gauge. Is the filter stem in place? If not, you won't have back pressure from the filter and thus no pressure to the bearings. Could be the sump screen is plugged with some of that crud. Maybe check the spring in the pressure relief. Might need primed if it was flushed out and if the check vavle in the pump is leaking????
 These ole engines will run for years with 5lbs of oil pressure.
Edited by CTuckerNWIL - 21 Apr 2012 at 7:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:15am
Okay I'll have to checking all.its h original guage so it should be right.ill just have to clean it out. I'm running an agcopartsbook filter from my local old Allis dealer so I think that's good I just think she's plugged up and needs to have the oil change s few times
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 8:26am
Agco sold bad filters for a time. If it has a rubber ring in the bottom and pleated filter, it's no good. There should be a tin plate covering the bottom with holes in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 11:49am
Okay I'll have to check when I change the oil thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 11:52am
If it's one of those bad filters, the engine won't run long with it on there without needing the crank ground and new bearings all the way around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 11:58am
So howdo I tell??
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2012 at 12:26pm
Take it off and look at it.  If it has a rubber ring in the bottom and pleated filter, it's no good. There should be a tin plate covering the bottom with holes in it.
Look at this link. The first picture is of a bad one the second is what you need.
http://personalpages.tds.net/~thompson_wp/acb/filter/oilfilter.htm
 Make sure it has this tube in it also.
Edited by CTuckerNWIL - 21 Apr 2012 at 12:28pm
johnlaf# View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnlaf# Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 12:39pm
I have a wd45 and just replaced the cam and new oil pump but my oil presher is low to no the old pump froze up help
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 1:08pm
would have been the time to install new cam brgs.good cam brgs are crucial to good oil pressure on these engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2020 at 1:29pm
You should start a new post, instead of hanging your question on another persons old post.
You might try pushing oil in the line that feeds the filter base, to help prime the pump. The filter AND the stem that goes up thru the filter have to be in place to develop any noticeable pressure on the gauge.
