D 15 brake drum
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 brake drum
    Posted: 08 May 2020 at 2:49pm
Having a hard time getting the drum on without unseating the woodruff key . Will heating the drum help ? Thanks !
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 9:18pm
Takes a good puller and some heat. Once it starts moving, don't stop.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 5:00am
Mack, i think he's tryin to get it back on...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 5:05am
hmm..
Could you use a LITTLE crazy glue to keep the woodruff key in the slot ?
Maybe bevel the top edges of the key where the drum slides on ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 5:34am
Yeah Jay that's kinda what I'm thinking . I'm also going to try some heat on the drum . I'll figure it out . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 5:37am
I'm wondering what 'trick' A-C did on the assembly line ? I try to figure out HOW something was assembled or made so dang fast.
It'd be nice to go back and SEE how they did it.....
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 5:38am
Heat The Drum It Will Go on Easy
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 6:38am
Guess I don't how to read at my old age.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 7:47am
Thanks guys . I'm gonna try some heat like I should have to begin with .
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 11:42am
Throw it in the oven for awhile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2020 at 4:59pm
Thanks John , I'm thinking more like heating it up with my propane torch .
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 4:59pm
The oven method works great for a ring gear so it should work just fine for that.  I had to wait for a day when the wife was out!!Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 6:18pm
If my little torch won't do the trick I'll probably try laying the drum on my gas grill . Using the wife's oven sounds kinda risky . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 11:16am
Grill would b better than torch....need to heat whole thing as try to just do the center could break it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 12:00pm
You're right Steve . I first tried the little torch , no luck . Happy to say I put it on the gas grill and finally have the drum back in place . I also put a dab of loctite on the bottom of the woodruff key . Now if only my parts would show up . Thanks !!
