d17 transmission drain plugs
AllisD17AndyOk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD17AndyOk Quote  Post ReplyReply Direct Link To This Post Topic: d17 transmission drain plugs
    Posted: 07 May 2020 at 9:12pm
just brought a d17 series lll and want to change transmission and rear end oil. I see a drain plug under the differential, and a smaller plug between it and the right brake housing. What is this smaller plug, do I drain both? Thanks, Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 9:21pm
Get yourself an owner's manual.  It will show you which plugs to remove and the capacities of the reservoirs.  They can be found cheap on e-bay and are full of valuable information.  Can't think of the small plugs you are referring to, but don't touch them.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 9:36pm
That is the bolt that holds lift ram pin in place.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD17AndyOk Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 10:12pm
Thanks Dseries4 for your advice...I have an owners manual and a shop manual, I read both over and over and find nothing showing the location of the drain plugs...please advise which page I need to read for this info...Thanks, Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD17AndyOk Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 10:13pm
Thanks, Mack, this is what I needed to know, I will now research that in the manuals...You have made me a wiser person...again, Thanks, Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 5:38am
When you do drain the rear end oil, be SURE to have TWO (2)  empty 5 gallon buckets handy ! If your D17 is like my D14 was, there'll be more than 5 gallons of oil in the diff...
..seems adding a quart of oil to the hydraulic system to get lift to raise , month after month ,year after year, kinda adds up.......
there's NO way a 5 gallon bucket can hold 7 gallons of oil ......Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisD17AndyOk Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 8:41am
Jay, guessing you must have found this out the hard way...according to my owners manual, my D17 rear end holds 24 quarts, that's 6 gallons, but my shop manual for the same tractor says it holds 28 quarts, that's 7 gallons...so based on your experience, I'm gonna have 3 buckets handy...Thanks, Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 8:46am
yeah... that was a FUN way to start the day......
I let the plug drop into the bucket......saves the panic wondering WHEN does it get out of the hole....
This page was generated in 0.027 seconds.
