6080 rebuild
ecarmich25 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Topic: 6080 rebuild
    Posted: 09 Apr 2020 at 6:52am
new to site i am rebuilding my grandpas old AC 6080 4wd tractor. had been sitting in the shop after he passed and went to turn it over and engine is locked up. took the head off water must have gotten down the stack because the valve is cracked. my uncle bought another 6080 2wd with bad trans, and were looking to do an engine swap and possible repair trans on 2wd but just focusing on one thing at a time at the moment. is there any advice anyone can give me before getting started. possibly tools i might need or things i should check or do once i have the engine apart?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:02am
From what I understand they had 14:1 and 16:1 compression ratios.  16:1 starts much much better.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 7:16am
So if you need pistons go with the higher compression ones if possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 11:58am
Sounds like you have multiple projects happening. If you are going to do a engine swap, the hood, radiator and anything else upfront will need to be removed. Anything that will be in the way of the engine being pulled. Do you have any idea what condition the main clutch and pto clutches are in? It would be wise to replace both at this time especially if it has quite a few hours on it. The clutches don’t hold up that well if not kept adjusted or abused. They are not that expensive. They are a bear to line back up if you split the tractor. What ever you do never try to force it back together or you will bend the clutch...trust me I know. It should slip back together with some wiggling. Make sure you use a clutch alignment tool. Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 2:09pm
As Doc said in the past,put 8010 piston kits in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2020 at 3:47pm
Is there a way to tell if you have 16-1 pistons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 8:34pm
thanks everyone for the replies. finally had the chance to work on it this weekend me and my dad. ill post some pics later. but i got both tractors tore down. removed front grill radiator. next question is i have a cherry picker up there and was going to try and pull it with that. my dad says he has a gantry i think its called but would have to dig it out. would it be easier with that or shouldn't have a problem with cherry picker?  also do i have to take the front wheels off? or does the two halfs seperate then as the cherry picker has engine just need another person and then just roll the frontend forward? and has anyone worked with 4x4 as far as the front driveline shaft linking to the rear? does anyone know how to take that off?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 8:39pm
lowell66dart
i would think this one is 16 to 1 ratio... its the 433I. i know when i took the head off valve number 2 is cracked so where just going to replace all of them. not sure the best way to do that thinking going to have to have a big press to put the sleeves in
Edited by ecarmich25 - 11 Apr 2020 at 8:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 8:55pm
That's a wet sleeve engine. When the block is cleaned GOOD you can push them in by hand.
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 10:00pm
The front driveline has a coupler at the front and middle of it.  There is a snap ring against each of them.  Loosen the snap ring on each and slide it to the end of the splines then you can slide the collars toward the center of the driveline and it will drop out.
The 433 is not too heavy (compared to the 6 cyl diesels).  Here is one on an engine stand, although it is a 2000lb rated stand.  It handled it just fine.
If you are going to switch motors I would pull the front end then the engine.  If you split it with the front wheels on still and then try to swap the motors around it is going to be a lot more work.  I used a regular engine hoist on this one.  I pulled radiator then the front off at the front frame rails, rolled it ahead and left the engine bolted to the trans then pulled it off.  To me it was really easy to work on that way.  It was one of the easier tractors I have taken apart, nothing much in the way or hard to get to.  If I remember right the frame rails aren't even that heavy, once that front end is off.
If you were just doing a clutch then a normal split would be easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2020 at 10:22pm
Ok so if you were to buy an engine kit for 6080, can you get a 16-1 kit for 6080.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 10:14am
Go to the parts book and compare pistons from 6080,F3,8010. If 16:1 was available for 6080 it should match up to something....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 1:20pm
Book list same piston for all 3. If they ever had a lower one it has been superceeded to to the higher.
Edited by SteveM C/IL - 12 Apr 2020 at 1:22pm
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 2:06pm
Use guide bolts on each side to align the block to to clutch housing. Cut the heads off and slip engine into place. Makes a world of difference.       Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2020 at 10:36pm
Thanks Steve, is there a kit part number, I'm not able to get on agco site. Thanks
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2020 at 8:00am
Click the log in as guest
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 6:02am
thanks leon, does anyone know how to take out the throwout bearing? the 2 bolts on the inside of the bearing ( fork screws) i believe are seiezed up or something. aren't giving at all. but good news got both the motors out yesterday hopefully after i get throwout bearing replaced im gonna throw it back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 9:07am
Yes you have to loosen the bolts on each of the bearing forks then rotate them out.  Soak them with your favorite lube and let it set and work in.  I would sure replace both of the release bearings and the pilot bearing while you have it apart, if you don't know how old they are.
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 12:42pm
I'm trying to remember some history.  Did AC buy the rear end from Fiat and build the rest of the tractor or did they buy the entire tractor, minus the engine and just install it at the US plant?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2020 at 6:24pm
Good question , Im pretty sure by pics , they bought the stuff from Fiat and assembled them in West Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecarmich25 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 7:20am
update. got the engines swapped over bearings replaced, everything put back on and loader on yesterday. finally!!! question??? so fuel pump is leaking and constantly have to open and close shut off valve to tank. i forgot to open and crank tractor and then dies, then i have to go back and crack heads and pump to get it to prime then tractor will crank. i talked to my dad and he thinks theres a vapor lock in the system. does anyone know what rebuild kit i need for the fuel pump or had this problem before? also my dad said that the fuel pump is timed, does anyone know once i take the pump off and repair it; how i do the timing once i put it back on because i have never done it before?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 7:27am
Fiat provided the chassis from the flywheel housing on back, including the clutch assembly. A-C did the engine, adapter plate, side frames, hood, radiator, air cleaner, batteries, front support, front axle, etc. Some of the hydraulic system was AC and some was Fiat. I think the platform/fuel tank/fenders were A-C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 8:01am
remove timing window on side of pump....turn engine advanced till 2 marks line up in window. Remove pump and don't turn the engine until pump is replaced
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 8:07am
Make sure you don’t have parts of the flex ring plugging things up. I’d also change out the o ring on throttle shaft. You also need to pull tank and clean it out.   6080’s are famous for getting crap in the fuel.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 8:11am
finding the timing line may be difficult, so to make it a little easier start watching when you get close to the 18* mark on front pulley. If no mark there, turn crank one turn, then look close as you approach the 18* mark. Spraying brake cleaner inside may cut the gummy coating if it is not nice and clean. The mark can be hard to see in a dirty pump.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2020 at 10:02pm
First thing I would have done is check the crank end play - these engines should have had a front brg setup on them to relieve the thrust from the clutches - few understood this and fewer are maintained.  The latest production had a wide thrust flange and different crank, these would wear out as well if the foot clutch and pto were depressed while cranking. No use starting a swap unless the crank is good.  My 2 cents worth... over .008 ,,,, bad news..
This page was generated in 0.158 seconds.
