Sickle Mower noise |
Page 12> |
| Author | ||
NE GA Allis
Topic: Sickle Mower noisePosted: 26 Apr 2020 at 7:11pm |
Hey all, we have been running a No. 3 sickle mower to cut down our small fields. My question is, how much noise should a sickle mower make while cutting? I realize that the mower is somewhere around 60-70+ years old and does have some wear, but I just want to make sure before something catastrophic happens. Pitman is tight on both ends, hold-down fingers are adjusted to where they should be. Knife blades are old but did sharpen up fairly well. It knocks a little bit when under load but gets really loud under heavy grass loads. Is that normal? Also trying to make sure I don’t run it too fast and shake it apart. Op manual says if it shakes the tractor then your RPMs are too high.
What gear should I be able to run this in on a WD or CA? On my WD I know my ground speed is too fast cause I have 16.9x28 tires (taller than 12.4x28) and had to slip the hand clutch in first gear in thick grass but could go full first gear in light grass. On the CA first gear almost seams to slow but cuts good and second gear seams too fast. Anyone have an idea of the RPMs on the PTO that I should be able run the mower at? Thanks in advance for any help. |
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s, 1 WD45, 3 D15D’s, 1 D17 |
| Sponsored Links | ||
MACK
Posted: 26 Apr 2020 at 9:19pm |
Are the guards and ledger plates in good shape? If not and hold downs aren't adjusted properly, they will knock. MACK
NE GA Allis
Posted: 26 Apr 2020 at 9:43pm |
I believe the guards and ledgers are in good shape. I replaced the bent guards with NOS guards. How can you tell if the ledger plates are bad?
HD6GTOM
Posted: 26 Apr 2020 at 10:26pm |
Most ledger plates have serrated edges. If you look at a new guard, you can see if they are worn out. Yes in tough grass, a mower with a pitman stick has a tendency to knock a little.
Brian G. NY
Posted: 27 Apr 2020 at 9:49am |
I guess the first thing I would do is turn the drive pulley back and forth by hand to determine where there might be some backlash. Do this at different pulley positions.
A sickle bar mower is inherently a bit noisy but when everything is adjusted correctly, it should not actually "knock".
Clay
Joined: 11 Sep 2009 Location: Udall, Kansas Points: 10425 |
Posted: 27 Apr 2020 at 11:35am |
When cutting wire grass, most mowers will knock. SLOW DOWN!!! If not, something on the mower will break.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3202 |
Posted: 27 Apr 2020 at 12:40pm |
New sickle sections will make a world of difference,correct pitman length is critical,those mowers are not made to run fast and do make a certain amount of racket.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9005 |
Posted: 27 Apr 2020 at 1:36pm |
...and ours broke the tube holding the pitman drive...
Brian G. NY
Posted: 27 Apr 2020 at 3:51pm |
This is a good point.......the "register" of the cut bar is one key to good operation. When the cut bar comes to the end of it's stroke the tip of each knife should be in the exact center of a guard. On Some mowers with pitman bars the register can be adjusted. I have a Twin-Wheel mower so I have not had to deal with this. The other critical measurement when setting up a mower is giving the cut bar a certain amount of "lead". On a typical 7 foot cut bar, the outer end should run between 1-1/2" to 2" ahead of the inner end. This allows for the natural deflection of the bar when it is operating. I still say there should not be a distinct "knock" when mowing. The quietest mower I ever recall seeing was a rear mounted mower on a 2N Ford belonging to my Wife's grandad back in the 50s.
NE GA Allis
Posted: 27 Apr 2020 at 4:48pm |
The register is correct. I think I found what most of it is. The blade assembly has a little bit of “forward and back” play (forward and back as the direction the tractor is traveling).
Is that adjusted with the wear plates? I have some new wear plates on the shelf.
NE GA Allis
Posted: 27 Apr 2020 at 4:51pm |
I’ve got a second No.3 mower with the same problem.
Brian G. NY
Posted: 27 Apr 2020 at 9:51pm |
Yes, that is just one more step in setting up the mower correctly. The wear plates have slotted holes so they can be moved forward to take up the play. However, they also wear out and need to be replaced periodically. You'll have this mower hummin' like a honey bee before you know it. LOL
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 609 |
Posted: 28 Apr 2020 at 8:14am |
My best guess would be timing - pitman is too long or too short and sickle sections are not "centering" on guards as mentioned earlier!
Brian G. NY
Posted: 28 Apr 2020 at 9:14am |
He says in one of his posts that the register is correct.
ac fleet
Thanks(1)
Posted: 28 Apr 2020 at 8:52pm |
You can't mow grass with a sickle mower---they NOT designed for that abuse!---They are only for weeds and clover , alfalfa ann that sort of cutting!---AND it's a wonder you have not wrecked it already!--your mower---do as you like with it!
Joined: 11 Sep 2009 Location: illinois Points: 91060 |
Posted: 28 Apr 2020 at 9:21pm |
everyone uses sickle mowers to cut the sides of the road in the country... and they are 90% grass.. If it is 2 ft tall, YEA, you got to slow down, but i cut 12- 18 inch grass pretty often.. Sometimes it clogs up and you have to stop and backup and "dump a load" then take off again.........if the grass is really thick. I have a side mower on a B... and i normally cut at 2/3 throttle... Im in no hurry.
NE GA Allis
Posted: 28 Apr 2020 at 11:39pm |
If a sickle mower was not designed to cut a field, then what was used before the disc/rotary mower was invented?
MACK
Posted: 29 Apr 2020 at 7:21am |
Sixth.
MACK
Posted: 29 Apr 2020 at 7:22am |
Sizth.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8662 |
Posted: 29 Apr 2020 at 7:48am |
If they are tuned up[ good I would think they should cut grass pretty well? We cut 60 acres of grass/ old hay fields every year for 10 years when I was a kid. We used a 5 foot antique horse drawn type sickle bar mower hooked to the Case VAI. I got to ride the mowing machine and try to lift the blade when needed. We plugged it sometimes, or ran into a ant hill once in a while. Grandpa kept new sections in it and it purred along pretty well. We never sharpened sections just replaced them.
On clover at my Dads farm we had a 7 foot New Idea pull behind. A field of clover went down in the wind and we had to mow in one direction. About that time Dad bought the New Idea Cut-ditioner (flail chopper) and the sickle bar was never used again. Regards, Chris
Edited by Sugarmaker - 29 Apr 2020 at 8:30pm |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8485 |
Posted: 29 Apr 2020 at 7:15pm |
I guess me, my father, and my grandfather have been doing it all wrong for over 80 years, and never knew it!
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4945 |
Posted: 29 Apr 2020 at 8:13pm |
yea, I hate hearing I was doing it all wrong growing up!
Allis Express North Georgia
NE GA Allis
Posted: 29 Apr 2020 at 9:38pm |
NE GA Allis
Posted: 29 Apr 2020 at 9:39pm |
NE GA Allis
Posted: 29 Apr 2020 at 9:43pm |
My mower works well, just was concerned about how loud it is.
Thanks to all for replies.
Posted: 23 Jul 2021 at 9:14am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12431 |
Posted: 23 Jul 2021 at 9:41am |
Wow, so angry! What the heck did people make hay with back in the day? I know I learned how to cut hay with a sickle mower at age 10, and we certainly didn’t have pure alfalfa. |
Tbone95
Posted: 23 Jul 2021 at 9:58am |
Yeah, use artificial grass!
You can feed artificial cows with it, and sell it to Burger King for Impossible Whoppers!!!![]() Edited by Tbone95 - 23 Jul 2021 at 9:58am |
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4885 |
Posted: 23 Jul 2021 at 11:50am |
How about we put a 3 D printer inside a big O'l plastic cow
an Impossible burger can pop out under her tail. End world hungry Bill Gates style.
Dang it how oh how did cutting grass end up solving world hungry. There be one or two very upset at changing the topic. T you and me got to be more careful of letting new guys get us get us in trouble.![]() ![]() ![]() Edited by Ray54 - 23 Jul 2021 at 11:54am |
Tbone95
Posted: 23 Jul 2021 at 12:09pm |
Page 12> |
