65' 190XT Help |
whizone
Topic: 65' 190XT HelpPosted: 18 Apr 2020 at 4:50pm |
I have 65' 190XT 3 with the D2900 engine less turbo. From what I can tell the turbo was completely removed and exhaust just straight piped up. My concern is how much HP will I have less the turbo and will the tractor perform well without it? Also, if anyone can fill me in on how the oil pressure gauge works and where its located I would be grateful. Further if anyone has an oil gauge and assembly laying around I would be interested in it. Thanks.
nick121
Posted: 18 Apr 2020 at 5:00pm |
I'd think it wouldn't run very good at all. No boost no power, smoke etc. Not an expert but I think the non turbo 301s are 70-85 hp max at the flywheel depending on setup.
Joe(TX)
Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Posted: 18 Apr 2020 at 6:23pm |
It's pretty much a straight 190 which was 77 PTO HP. Probably smoke a lot unless the injection pump has been turned down.
ac fleet
Posted: 18 Apr 2020 at 7:29pm |
Not something you want to try doing serious work with! ---A pooch for sure!
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 18 Apr 2020 at 8:32pm |
There is no oil pressure gauge on these tractors. They use a red low pressure light on the dash. The sensor is behind the fuel filter on the right side of the engine.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 18 Apr 2020 at 9:28pm |
you can plumb a mechanical gauge to the block easily. beware white/clear plastic lines...short lived
DougG
Posted: 19 Apr 2020 at 8:59am |
Use copper tubing , not the plastic stuff, they run good and not a pooch- as was mentioned LOL, - head shaking- match them with the right implements is the thing
whizone
Posted: 19 Apr 2020 at 2:14pm |
Thanks everyone for the input you guys are great! Would it be worth the cost of putting a tubo on it as I'm only going to pull my 15' batwing with it on 40 acres?
DougG
Posted: 19 Apr 2020 at 2:34pm |
No not all , that engine will handle it fine, some of these respones are rediculous,,
Edited by DougG - 19 Apr 2020 at 3:37pm |
