Allis 301 diesel water to the block only= dry head |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7977 |
Posted: 04 Apr 2020 at 4:22pm |
Got a 301 diesel puller that im wanting to run a filled head to get away from the cracking issues, question is , where would be a good entrance for the water to the block? Im thinking about returning it from the water drain on the injection pump side, anyone do this before ?
Orange Level Access Joined: 12 Sep 2009 Points: 19662 |
Using the AC water pump, use a 180-185-190 (NOT XT or 200) water pump volute to pump water into the front of the block, then drill a hole or two to get water flow into the #1 sleeve area. Drill two holes in the rear of the block below the head gasket/deck area and let hot water out there. We've used two 1/2" pipe nipples for the exist. !/4" pipe is the block drain and will flow very little and won't move water 100% thru the block and out.. All drilling done with a bare block.
Acllss puller
Bronze Level Joined: 02 Oct 2013 Location: Ny Points: 181 |
I used mezerle 20 gallon pump and circulated it from front of motor to rear soft plug on the right above the starter then through an oil cooler with 5/8 fittings and electric fan to fit with a one gallon expansion tank for relief , I may still have some of it ???
DougG
Where did you enter the front of the engine?
Acllss puller
Right front corner of block facing forward , made a plate with 3/4 “ inlet I think big water volume helped keep temps even across cylinders , I’ll check tomorrow see what I got to take pics for ya ?
DougG
That would be great , thanks
Acllss puller
So I mane a plate to bolt over the hole that the stock water pump used And also bolted across the entire front of the block to serve as a place to pull engine from here is a pic of it uploads
DougG
No pic but dang that makes total sence to make that plate where the pump was
Acllss puller
So I made a plate to bolt over the hole that the stock water pump used And also bolted across the entire front of the block to serve as a place to pull engine from here is a pic of it uploads . Can’t seem to get pics to upload on here , text me and I’ll send some . 716-866-2114
TeamAllis
Bronze Level Joined: 15 May 2013 Location: Bath NC Points: 43 |
I have some pictures of what we ran on our 180. Text me your number and I will send you pictures of our set up. We are currently running a dry block now and not having any problems. 252-945-7937-Jamie
Bobo Husker
Silver Level Joined: 28 Nov 2016 Location: Muscoda, WI Points: 96 |
I would like to see what you guys did also if that's ok. 608-604-7752
Thank you in advance! |
