D15 series 1 electrical |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10576 |
Posted: 30 Mar 2020 at 6:26pm |
What would cause system to not charge battery if regulator and generator are working? Can a wire on or near amp gauge cause this? Thanks Tracy
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 613 |
wire or bad amp gauge
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7234 |
I have seen many old ammeters crap out. Start there. If not, have a good look at your wiring harness.
MACK
How do you know generator and regulatory are working? MACK
TimNearFortWorth
Orange Level Joined: 12 Dec 2009 Points: 2014 |
Thanks(1)
Tracy, I had a 15II that had me stumped.
Re-worked gennie, all new good quality gauges and even changed out the VR as new wiring harness to boot and I wanted to start fresh. Would run a new battery down with normal use and had to keep charging it. If you had the battery out of it since or even unhooked the terminals it will need re-flashed with a jumper wire and the 3rd time I flashed it, she charges pretty darn good and can sit for months and fire right off. Any time I unhook a battery on a gennie unit, I re-flash em' anymore.
bleeds orange
Orange Level Joined: 11 Sep 2012 Location: mt. vision, ny Points: 662 |
Hey tim I guess you could help with "reflash" how and what do you do? Be useful information for future.
Thanks cory |
Tracy Martin TN
Mack, had them off and checked twice. New rebuild and new regulator. Charged on bench. Thanks tracy
bleeds orange
Thanks cory |
TimNearFortWorth
With batt charged up and hooked to tractor, use a jumper wire to flash across the F (FIELD) terminal on VR, to the positive post on battery. Should see a spark when you touch it to the F terminal on the VR, only takes a second.
Can also flash by using a short wire between the F and B (battery) terminals on the VR. This is typically required whenever the battery terminals are removed on the battery as in replacing/changing battery and I have had good luck doing it on batteries that have been run down completely that I have charged back up in the tractor. Sometimes needs to be repeated occasionally on old systems.
