D12 Backhoe project completed |
Burl
Silver Level Access
Joined: 13 Sep 2014 Location: Aurora Mo. Points: 232 |
Topic: D12 Backhoe project completedPosted: 07 Mar 2020 at 7:13pm |
Would like to spray hoe orange but that is a LOT of masking !Hoe mounted to sub frame ,3pt. removed .
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 07 Mar 2020 at 7:25pm |
Nice setup Burl! Beautiful job!! Steve@B&B
Reindeer
Joined: 14 Sep 2009 Location: Calgary, AB Points: 655 |
Posted: 07 Mar 2020 at 7:35pm |
Very nice¡
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4191 |
Posted: 07 Mar 2020 at 7:55pm |
Burl
Silver Level Access
Posted: 07 Mar 2020 at 8:34pm |
Thank-you - Should have put these at top but, the story is, I picked it up 30 min. before it went into crusher . Got lucky !
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3987 |
Posted: 07 Mar 2020 at 8:44pm |
thats a nice looking rig looks like you did some nice fab work, i am guessing that you had to biuld all the hoe attachment mounting . what brand is the hoe attachment ?
HudCo
Posted: 07 Mar 2020 at 8:47pm |
missed that veermer ont the top
Burl
Silver Level Access
Posted: 07 Mar 2020 at 8:51pm |
It took me 4 weeks to make subframe . I made it all out of wood before fab. the steel parts . Its a Vermeer hoe off a trencher .
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8731 |
Posted: 07 Mar 2020 at 11:13pm |
With all the obvious work fixing that tractor up it's no time to go wobbly on painting the hoe. Get to masking and maybe some careful aiming and you will have it matched up in good time. It will be worth it when done. I assume it's more work to remove than to mask.
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
Posted: 08 Mar 2020 at 7:28am |
You did a great job. You have come a long way from where you started.
Jk chalmers
Joined: 19 Apr 2018 Location: Delaware ohio Points: 295 |
Posted: 08 Mar 2020 at 8:04am |
Great job saving it! It looks great maybe I’m just biased to anything D series but that little tractor is on my list to have..!!
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 08 Mar 2020 at 8:36am |
Good save, great work, and I know you'll paint it. You just want to enjoy it for a bit, who ya gonna bury first.
Burl
Silver Level Access
Posted: 08 Mar 2020 at 8:46am |
Thanks again ! The hoe can be removed or attached in 15 min. I use alum. foil to wrap hyd. hoses but , where they all come together on control body is a nightmare !
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5909 |
Posted: 08 Mar 2020 at 8:49am |
Very nice looking set-up. Have you considered repainting the tractor to match the Hoe. I believe the I-40 and I-400 were a yellow similar to the Hoe. https://www.mylittlesalesman.com/1972-allis-chalmers-i400-tractor-10109193 |
Joined: 11 Sep 2009 Location: illinois Points: 89139 |
Posted: 08 Mar 2020 at 8:55am |
VERY NICE............. a few resize
Cernunnos
Joined: 30 Jul 2014 Location: Ridgeland, WI Points: 361 |
Posted: 08 Mar 2020 at 9:30am |
Great save from the crusher! What brand are the front wheel weights?
Burl
Silver Level Access
Posted: 08 Mar 2020 at 12:25pm |
Thank you Steve , I never can get them correct . Wheel weights are IH . $40 for the pr. I like Orange !! Maybe spray hoe this summer if I get caught up.Would look nice with AC decals & paint.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 09 Mar 2020 at 4:17pm |
That is GREAT work Burl. Yeah, you'll paint it. It's gotta match!
Did you get the weights in the pic too? |
GeneD14
Posted: 09 Mar 2020 at 7:02pm |
Nice job mounting the backhoe. I like that you used a sub-frame, instead of just using a 3-point mount.
Burl
Silver Level Access
Posted: 09 Mar 2020 at 7:11pm |
Did not get any of the suitcase weights on ground. It did come with custom railroad track weight chained to front axle. I did make that 4 in. sq. tube hanging from front axle. Filled with melted lead auto wheel weights, ended up weighing 90#.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 09 Mar 2020 at 10:40pm |
Of course you need a loader on the tractor to balance it and make it easier to refill the hole the hoe dug.
Allis Express participant |
