disc
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Topic: disc
    Posted: 24 Feb 2020 at 7:14am
Question?  What would be the series or model number of a 6' snap couple disc.  Would like to buy the manual etc but want to make sure I get the right one.
Edited by Trinity45 - 25 Feb 2020 at 2:03pm
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 8:03am
Can you post a picture on this site? AC made many different models of discs.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2020 at 2:25pm
I will try to get one tonight if the rain lets up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 2:36pm
Attached is a picture of the disc, it is just under 6' across the back.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 3:49pm
That is a 100 Series disc.  So, yours would be a #106.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2020 at 4:28pm
That is a 100 series
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2020 at 8:33am
Here is a pic of my Allis-Chalmers snap-coupler #109 disc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 7:09am
Thanks, I will look on ebay and see if there is a manual for this series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 7:19am
So here is my next question, how well do they work the soil, I just sold my bigger wheel disc about two weeks after I bought this one for my CA, so this is my only disc for now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 7:58am
They're not very heavy.  You'll probably be okay in the spring with soft dirt.  They'll do a pretty good job in that capacity.  However, in the fall with hard, dry dirt you'll probably have to make at least two passes if you're trying to cut cornstalks or even heavy soybean residue.
I used a 4" disc grinder to sharpen my blades.  It took awhile but seemed to help a little bit (maybe it was just wishful thinking).
Good luck.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 8:09am
I've never liked a rigid disk like that as much as an old pull type that  gangs sort of worked
independently.Good thing about that style is it can be lifted when disking something like a garden.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 1:43pm
That is what I bought it for was garden work, we pretty much stopped farming and I was using a 10' wheel disc on a 185 but found this just down the road and I have two CA's, I intend on selling the 185 down the road so letting the wheel disc go was not  a hard decision.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2020 at 2:23pm
You may find you'll need some front wheel weights on the CA.  Maybe even the engine/side weights.  I know I needed front wheel weights for my WD-45 when I hooked up to my disc.  I can still pop the front wheels off the ground if I pop the foot clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 8:23am
I am on the look at for some, we built a rack that bolts on the front end to put slab weights if I have to go that route.  I have both a tricycle front and a wide front CA, the wide front may need less weight on the front.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2020 at 10:36am
CA side weights are kind of hard to find.   This is an ad for B C weights in TN.  They will work on a CA, but are shorter.   You just have to rig the front mounting bolt.
Edited by Larry in NC - 28 Feb 2020 at 10:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 1:20pm
I found this on ebay, the same picture as you posted on the forum!
106 Allis Disc
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 9:14am
Yep, I used that picture, I just bought a disc exactly like that from a lady about 20 miles down the road.  They just used it like a pull type disc, did not know what brand it was etc.  I gave her $300 for it, sold my wheel disc to a young man about 15 miles away for $600, wanted more for it but I knew his family and he just bought a small farm so I cut the price.  I have two CA's and a set of 2-24 plows, now I have a disc to fit one of them.  I have a 3pt conversion for them was well.  Next project is to find a planter.
This page was generated in 0.473 seconds.
