AC 170-175-180-185
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Topic: AC 170-175-180-185
    Posted: 01 Jan 2020 at 11:03am
Do I have this right?  The 175 in just a newer version of the 170 and the 185 is just a newer version of the 180.  What are the real life differences and which is a better tractor?
Bill
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 1:06pm
you can search the archives here, but engine rpm, trans and torque housing gears, final drives have some different parts, 236 vs 248 perkins engines are some differences.  The tractors are 90% the same.  170 and 175  and 180 185 built in overlapping years.
Visit www.agcopartsbooks.com and start comparing.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 1:08pm
Yes, the "5" tractors were simply sped up versions of the "0" tractors. For instance, the rated load rpm of a 180 is 2000, and 64 pto hp, the 185 is rated at 2200 and develops 74 pto hp, while fuel setting is only slightly higher. The marketing strategy was to pull the same smaller equipment faster than the previous tractor you used, thus saving drivetrains. As speed increases, the torque falls, torque is what does the work, but also damage. By the time these tractors came out, a 75hp tractor was no longer the big horse anymore either, in many cases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 8:58am
hey Ed, what is difference in timing advance ability between the pumps with and without the trimmer screw in the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 10:19am
Without digging spec sheets out, ones without advance are the same whether 180 or 185, the ones with advance are same as each other as well going odd memory. It seems they have 5* pump advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 10:23am
I seem to remember 24 degrees BTDC on the old non-advance engines and 18 degrees BTDC on the later models ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 10:32am
26* on non advance, 180 w/advance is 22*, 185 with advance is 24* according to a sheet I have for all sorts of AC applications. They would probably start better at 18* lol! The 200 tractor underwent many changes, first pumps were 5* and timed at 24*, then went to 8* pump advance to time engine to 18* for better starting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 12:25pm
From a wiring point of view, there are some minor differences at the dash and going out to the engines looking at a couple OEM harnesses that I have here. Not sure on the rear lighting harnesses. Never could get a rear harness that wasn't cobbled up!  LOL!
Steve@B&B
This page was generated in 0.085 seconds.
