Cracked B block
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: Cracked B block
    Posted: 19 Dec 2019 at 8:38pm
Friend of mine has a B with a crack in the block between the cylinders. Is this repairable? Or should he be looking for a new block?
Cheers
Creek
Have spacesuit, will travel
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:46pm
Small cracks are not a problem.. If it is bigger than 1/16 inch, Dick L had a procedure several years ago to remove the freeze plugs on the side of the block, cross drill holes between the liners, and pull the block back together.... maybe he will post a link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 8:51pm
[TUBE]Pq0wfU4ZaKk[/TUBE]
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2019 at 9:00pm
Nevada Cylinder Head at Nevada Iowa welds and straightens the bores of broken blocks.
Gerald J.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 5:35am
Hair line crakes between cylinders are normal in wet sleeved engines when they have been over heated. They do not cause a problem. The head gasket seals them just the same as the crack that runs 360ยบ around the out side of all wet sleeves.
If you have a crack wider than a hair crack it can be pulled back with a tie bolt. Tie bolts were used early in manufacturing some wet sleeved engines to prevent cracking. It was used to repair these engines by dealerships in the 40's and most likely earlier. I picked it up from an old tractor mechanic and took pictures to pass it on to DIY ers using simple tools most have or can obtain inexpensive easily.
https://public.fotki.com/DickL/tie_bolt_story/
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 6:18am
WOW, them old guys KNEW how to do neat stuff !!!
New use for bacon grese too !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 6:54am
Those pictures are great documentation!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 7:13am
If you care to replace, I have some  blocks without cracks for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2019 at 8:21am
Thanks for your input, I will pass it on to him. I thought I remembered that the crack between the cylinders was fairly common in the D17 diesels, but didn't know if it applied to the smaller gas stuff too.
Lon I will let him know you have a block in case he wants to go that route.
cheers,
Creek
This page was generated in 0.127 seconds.
