How to attach rear glass to hinge on allis 7000? |
wjoey
Bronze Level Joined: 12 Aug 2019 Location: GEORGIA Points: 17 |
Posted: 15 Sep 2019 at 1:57pm |
How to you attach the rear glass to the hinge on a allis 7000 the side glass looks to be some kind of rivett , I asked my dealer and he said use bolts and nuts ?
Alvin M
Orange Level Joined: 24 Jun 2018 Location: PA Points: 728 |
Thanks(1)
You Can Get Rivets Bushings And Washers From Agco
wjoey
Alvin M
Yes Same As Side Windows
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4372 |
Not knowlegable on a tractor so may be all wrong. But on a MH Gleaner I have done the side window you open to check the return elevator. Plane old aluminum pop rivits worked for me. I believe I have done it twice by now.
MACK
Have saw them explode using pop rivets. MACK
REEDE
Silver Level Joined: 24 Apr 2010 Points: 283 |
We use # 10-32 machine screws and nuts , can not remember the length of the screw.
PeteMN
Bronze Level Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 192 |
If they are like the 8000 series back window then you need wide flange aluminum rivets w/aluminum pins(not steel) and they have plastic bushings that fit inside the holes on the glass to add a little support. Nobody locally had that length aluminum rivet w/wide flange so we ordered a box of them from McMaster Carr.
Manchester Allis
Bronze Level Joined: 04 Jul 2018 Location: Manchester, Ia Points: 19 |
I had to replace the hinge on my 7040 back window 2 years ago. Got the hinge and rivets from a local A/C guy. He said to use a hand operated riveter and get the rivets tight but do not pull them tell they pop. Seems to be holding fine.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8162 |
Do you know if you buy 8000 window or hinge from agco, does it come with rivets an hardware stuff.
How's the hinge attached to tractor Edited by Mikez - 03 Oct 2019 at 9:51pm |
PeteMN
I'm not sure what comes with a factory window. I priced one for our 8000 series and then bought a new back window from All States Ag Parts, it cost $215 for the glass only(shipping would have been cost another $100+ so I picked mine up at their warehouse). I bought rivets from McMaster Carr. I ground off the old rivets to reuse the hinge and saved the plastic bushings that fit inside the rivet holes. I set the hinge on the window making sure I had it the right way, inserted all the rivets and plastic bushings, and then fit the steel washer on the rivet and riveted every other one, and then came back and did the rest. The hinge has narrow slits on the side away from the rivets and those slits fit onto a u-shaped bracket at the top of the window opening. It takes two people standing on sturdy step ladders to safely tilt the window out to almost level in order to line up the slits with the bracket.
Mikez
Thanks Pete, we ordered one from agco and we pecked into the box an hinge and handle is on it
wjoey
I ordered and used the rivets and bushings from agco , I was nervous about breaking the glass but all went well, Thanks all for the help!!
