Cleaning D-14 gas tank
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning D-14 gas tank
    Posted: 05 Sep 2019 at 4:48pm
My D-14's gas tank has sat empty for a number of years. It has a light coat of rust on the inside. Doesn't cover the whole tank. What is the best way to get rid of the rust? If I should line the tank afterward, what is a good product for doing this? Thanks. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 5:24pm
I used a tank liner kit from the local auto parts store.  The cleaner they use is muriatic acid so you could get some of that and try it.  Another recommendation is put nuts and bolts, or gravel in the tank, strap it to a tractor wheel and drive around for a while.
You may want to increase your font size.  Most of the older guys on here won't be able to read it.  Heck most all the guys on here!!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 7:26pm
Lightly sand blast the tanks bottom and shop vac out the sand and then power wash and air dry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2019 at 8:28pm
I have done what John has suggested several times.  I have had good luck.  Any local garage should be able to do an acid soak (or more) to get the rust out.  IF it still looks flaky after that, then get it lined.  You will never have a rust problem again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2019 at 5:13am
The age old farmer fix was to strap the tank to the rear wheel of a farm tractor, put some varsal and a light chain inside the tank, attach cap, and go do something, like plow, disc, or bush hog, a couple hours, with the tractor...  Multi-tasking, at its best.  I'da posted a video, but couldn't find the original of one of the forum members, here doing this, with a WD-45...
I hate to give the copy-cats any more views, for an idea they stole, here...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2019 at 7:54am
Thank you for the responses. I think I will try the muriatic acid first and see how that works. It's not too bad looking, so hopefully it will clean up easy. I make the font one size bigger so I can proof read it better. I could always make it bigger! Thanks. rrhead(SD)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2019 at 5:49pm
If you use the muriatic acid, you have to neutralize it right away, and it will most likely flash rust some before you are done rinsing it out.
