engine rear seal
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: engine rear seal
    Posted: 29 Aug 2019 at 6:03am
have anyone tried something to slow down a leak on the rear seal of an allis engine. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 7:25am
Remove engine and crank and reseal is one option. But usually other things happen when your in there! I know this wasn't what you wanted to hear. Not sure of any quick fixes? The experts will be along soon.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 7:39am
What engine?        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 9:14am
d-17
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 9:19am
How about a bit more about the engine, is it gas or diesel? Which series D17?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 3:13pm
series one. gas. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 6:55pm
If it has a rubber seal , Lucas makes good stuff, also brake fluid will make rubber seals swell,, just depends on your choice to get by or a tear down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 8:50pm
Take it apart and replace it.  Anything else is just a temporary band aid.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 9:13pm
Don't cut ends of seals off. Glue seals in their grooves. Use the F gaskets that comes with pan gasket. Be sure bearings have proper clearance. Oil the seals before installing crank and main caps. Put some sealant on top aluminum seal retainer before bolting it to block.        MACK
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2019 at 9:25pm
My folks had a dodge dakota that decided to start leaking badly all of a sudden. As a desperation move, they used Blue Devil rear main sealer. Got it at an auto parts store locally, dumped it in and never had any more trouble with it. Could have been a fluke, but might be worth a shot?
This page was generated in 0.101 seconds.
