AC disc repair
onestout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote onestout Quote  Post ReplyReply Direct Link To This Post Topic: AC disc repair
    Posted: 20 Jul 2019 at 5:44pm
New to the forum, first time post.
I have an older 14' wide disc (not sure which model it is, no tag or marking) and I lost 1 gang.  bearing holder and shaft broke.  I like my older AC stuff but I'm having a hard time finding parts for this.  Is it worth it to try and salvage or would I be better parting it out and find a different disc (tough to answer that)?  The shaft is a 1" hex.  It's too bad, it sure worked good when it was working.  I saw the pinned thread on the bearing rebuild, does that work for the Hex shaft as well?  Thanks
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 5:54pm
I have a couple of parts disks. Give me a call Ryan 402-469-1738
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 9:23pm
Welcome to the forum...I am at Somerset/New Richmond...Dale
Orangereborn
Dale Schafer
964 192nd Ave
New Richmond, WI 54017
715-247-3079
Cell 715-781-2055 Text
Orangereborn@hotmail.com
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 6:52am
The round and hex balpak bearings are the same. The bearing has an inner sleeve that pressing out. It can be either a round or hex sleeve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 10:07am
If the rest of the unit is solid, frame, axle mounts, hitch and not all cobbled up with old welds, you can look at replacement gang assemblies.
Numerous supply companies can supply the entire gang with hanger brackets that can be welded directly to your frames.
Pick common carriers that are easy to reach for lubing, blade type, size/thickness and hangers, just watch you do not oversize what it originally had as too aggressive will not last as some of those older discs had pretty light frames.
Post Options Post Options   Thanks (0) Thanks(0)   Quote onestout Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 12:24pm
Thanks for the responses.  I am looking into our options.  I am guessing the other bearing and shafts are going to be in the same condition but it was raining so I didn't have a lot of time to look at it.  Overall the frame and everything seems to be in pretty good shape.   Any help on the model #?
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 1:02pm
Looks like a 2300 old style hangers and bearings   Frame looks to be in good shape
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2019 at 6:46am
Is it a 2200 disk? Dad has a 2200 in the weeds that I intend to restore some day but they are prone to breaking the hex spindle axle.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2019 at 12:24am
Orangereborn
Dale Schafer
964 192nd Ave
715-247-3079
Post Options Post Options   Thanks (0) Thanks(0)   Quote onestout Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2019 at 10:20pm
thanks for all the replies.  I will figure out what I need and get in touch with you.  Great site and good to see the old stuff kept up.
