d17 loose front end
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: d17 loose front end
    Posted: 10 Jun 2019 at 5:12am
looks like the front axle pin is coming out of the front bollister, is the only thing that keeps it in place the bolts in the axle assembly hoop under the engine/trans?
Edited by dt1050 - 10 Jun 2019 at 5:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 5:32am
it's a series I d17 wide front, with power steering..
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 6:13am
Yes.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 6:19am
k thanks, i guess I'll have to put some shims in the back and tighten it up some. probaly over an inch of play right now
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:22pm
I would pull that axle out and check that pin for excessive wear.  Seeing it has a loader, I would rather have a new pin with lots of metal on it.  The bolt at the back of the wishbone will probably have plenty of wear on it too.
My local fab shop welds new pins on all of my tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 5:30am
good idea, unfortunately I'll have to wait to pull the front axle i'm in the middle of digging out an embankment, moving the barn (it's on skids) and fixing my fence that the Censored deer destroyed this winter...always glad when winter is over, but man the work piles up for when the weather breaks....
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 6:13am
Depending on how old your tractor is there could be a bushing in the front axle support casting. My early D17 had a grease zerk added to the front casting like the later tractors.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 11:45am
I think it's a 1957, I ran the serial number years ago...have to check again.  I know it's old and worn out like me....lol
This page was generated in 0.281 seconds.
