B drawbar?? Update
Wdtractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Topic: B drawbar?? Update
    Posted: 01 May 2019 at 2:29pm
Can anyone get me the measurements of a b allis swinging drawbar. Length, with, and hole size. Thanks Wil
Edited by Wdtractorman - 19 May 2019 at 11:30pm
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 5:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 8:57pm
Thanks for the reply. Iv got everything but the actual straight swinging part. There a machine shop we do business with at work with has some 2 1/2 x 1 flatbar, and says they can cut off a peace and punch the holes for 20bucks if I can get the measurements.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 10:58pm
Just measure from your swinging mounting point to 14" behind the end of the PTO.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 5:59am
Maybe contact that seller and see if they would measure it for you. Never know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 6:41pm
Take a piece of wood, the length you want, of dimensions, that will fit in the front bracket, drill a hole, in the wood, of the correct diameter, then trace, or transfer punch the location, of the rear hole, with the front hole pinned in place.  That should give you the template, that you need to make an iron copy...Wink
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 8:55pm
Boy this is funny. I brought that drawbar home with me today. I was down there for a baseball tournament and made a little side trip!
So exactly what measurements do you need? Just the drawbar part?
The mechanic always wins.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 9:00pm
Man see how the tractor Gods work!
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 9:13pm
I called on it this winter and it took till now for me to get down that way.
All measurements are approximate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 9:18pm
Bah!  That 5/8" hole, is 1 3/4" from the edge of the bar to the CENTER of the hole. The drawing looks like to the edge. Sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 9:51pm
Thanks. That should be all I need
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2019 at 10:00pm
Mine will be a little beefier they have a peace of 2 1/2x3/4 flat bar there going to make it out of but I don't think that will make any difference really. Thanks agin
Edited by Wdtractorman - 05 May 2019 at 10:09pm
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 7:09am
I have one for sale $50
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 11:37pm
I got my swinging drawbar made. It a little bigger that stock mine is 2 1/2 wide x 3/4 but seams to work fine anyway. I may try to trim the with down to stock but idk.
Another question for every one, dose all b's have on the left final drive a 1/2 hole for the drawbar pin bolt and a 5/8 on the right ? Or are both of mine having that just a fluke?
Thanks Wil
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 4:48am
Someone fluked it after the bolt became loose took out the threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wdtractorman Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 11:19am
It just odd both of my b's have the small hole on the same side and large hole on the other lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2019 at 3:54pm
I can't help you with a why but they were 1/2" both sides to start. At least all the older ones were. 5/8" always seemed like a better deal anyway.
This page was generated in 0.067 seconds.
