B drawbar?? Update |
Wdtractorman ![]() Orange Level ![]() Joined: 24 Sep 2013 Location: Kentucky Points: 975 |
![]() ![]() ![]() ![]() ![]() Posted: 01 May 2019 at 2:29pm |
Can anyone get me the measurements of a b allis swinging drawbar. Length, with, and hole size. Thanks Wil
Edited by Wdtractorman - 19 May 2019 at 11:30pm |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2677 |
http://wausau.craigslist.org/atq/d/adams-c-draw-bar/6865470476.html Too bad this is a long ways away.
Thanks for the reply. Iv got everything but the actual straight swinging part. There a machine shop we do business with at work with has some 2 1/2 x 1 flatbar, and says they can cut off a peace and punch the holes for 20bucks if I can get the measurements.
Just measure from your swinging mounting point to 14" behind the end of the PTO.
Maybe contact that seller and see if they would measure it for you. Never know.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54118 |
Take a piece of wood, the length you want, of dimensions, that will fit in the front bracket, drill a hole, in the wood, of the correct diameter, then trace, or transfer punch the location, of the rear hole, with the front hole pinned in place. That should give you the template, that you need to make an iron copy...
littlemarv ![]() Orange Level ![]() Joined: 10 Jun 2013 Location: Wisconsin Points: 1834 |
Boy this is funny. I brought that drawbar home with me today. I was down there for a baseball tournament and made a little side trip! So exactly what measurements do you need? Just the drawbar part?
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
Man see how the tractor Gods work!
I called on it this winter and it took till now for me to get down that way. All measurements are approximate.
Bah! That 5/8" hole, is 1 3/4" from the edge of the bar to the CENTER of the hole. The drawing looks like to the edge. Sorry.
Thanks. That should be all I need
Mine will be a little beefier they have a peace of 2 1/2x3/4 flat bar there going to make it out of but I don't think that will make any difference really. Thanks agin
Edited by Wdtractorman - 05 May 2019 at 10:09pm |
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2033 |
I have one for sale $50
I got my swinging drawbar made. It a little bigger that stock mine is 2 1/2 wide x 3/4 but seams to work fine anyway. I may try to trim the with down to stock but idk.
![]() Another question for every one, dose all b's have on the left final drive a 1/2 hole for the drawbar pin bolt and a 5/8 on the right ? Or are both of mine having that just a fluke? Thanks Wil |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Someone fluked it after the bolt became loose took out the threads.
It just odd both of my b's have the small hole on the same side and large hole on the other lol.
I can't help you with a why but they were 1/2" both sides to start. At least all the older ones were. 5/8" always seemed like a better deal anyway.
