stuck clutch |
Riverok
Joined: 28 Jan 2019 Location: Tahlequah, OK Points: 6 |
Topic: stuck clutchPosted: 28 Apr 2019 at 12:41pm |
Looking for advice on freeing a stuck clutch plate on my Model B AC. The tractor has been sitting idle for several years and I finally got it running but the clutch is stuck apparently. Riverok
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 28 Apr 2019 at 7:41pm |
What I have read about this is first of all you have to start it in gear. Give yourself plenty room . While moving depress the clutch and jam the brakes hard. Should pop loose. What gear to be in is anybody's guess. I would try first or reverse or try both
MACK
Posted: 28 Apr 2019 at 8:12pm |
Use hi gear. MACK
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Posted: 28 Apr 2019 at 8:25pm |
When I first got my CA the clutch was stuck. I chained it to a big tree put it in first gear, pushed the clutch in and started the tractor. You may need to be quick to shut off the tractor as the front may what to came up on you. I didn't have that happen. For me the rear wheels just spun a bit until the clutch broke free. Just be careful what every you do.
Thanks & God Bless
Dennis |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 29 Apr 2019 at 6:51am |
Dennis I just put some gears in a Ford trans because someone told owner of tractor to do the same thing .I would not do that .Look up in inspection hole if things have a lot of rust on them just split tractor.
Brian G. NY
Posted: 29 Apr 2019 at 7:07am |
Back in the 50s my Dad's B clutch stuck....my brother and I pushed him in high gear to start it and he did exactly that. As I recall, it freed up after a couple of tries.
Edited by Brian G. NY - 29 Apr 2019 at 7:12am |
Brian G. NY
Posted: 29 Apr 2019 at 7:12am |
I guess you would have to leave a bit of slack in the chain in order to start the tractor? Seems a little scary.....high gear is better as you need as much resistance as you can get.
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54696 |
Posted: 29 Apr 2019 at 9:28am |
If its stuck from sitting, sometimes you can spray in some light penetrating oil, and try rocking back and forth, while its in gear, with the pedal chained down. Now if its been submerged in a lake, or has a massive oil leak, that has dried to a tar like resin, its a different story...
DennisA (IL)
Posted: 29 Apr 2019 at 10:01am |
Ouch, first gear at low idle shouldn’t break anything. I’ve had the CA sitting and spinning a few times without issues. Allis built these tractors like Sherman tanks. Just don’t grind the gears. |
Thanks & God Bless
Dennis |
