calcium antidote
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: calcium antidote
    Posted: 10 Sep 2010 at 10:37pm
I have a tire that sprung a leak with calcium chloride peeing all over the wheel. Is there anything I can spray/toss/dump on there to neutralize the situation until I can get to taking the tire/tube/rim apart?
I am still confident of this;
Wait for the Lord;
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 10:45pm
I have one doing it also, when I park it on concrete I make sure the valve stem is on the top.  Sometimes I have to jack it up and rotate.  I'd just wash it with a hose, isn't it basically very concentrated salt water?
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2010 at 7:43am
Don't know of any "nuetralizing agent" (othe than lots of water and soap). Have noticed that the valve cores are the weak link with CaCl filled tires. I now change out the cores every other year (or more often if notice seepage). Rotate the tires so the stem is at the top, jack up the tire, bleed out the air, replace core and repressurize the tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2010 at 7:54am
Lots of water, then more water. If it is leaking into rim (inside of tire) you need to get it drained and off soon. I used a small pump to suck it out along with air into tube , rotate valve to top, air tire with valve core removed, attach hose and rotate to bottom as hose discharges into drum. Lower jack to create more pressure on tire bottom to force more out.
 Jack it up and do again
