6060 tach/alt |
murdoc ![]() Bronze Level ![]() Joined: 25 Mar 2011 Points: 32 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Jan 2019 at 9:39am |
Ok guys my tachs not working I know it’s signal comes from the alternator the alternator has been repaired with a 1 wire alt so I know its gotta be replaced with another the wires are there I think can somebody send me a picture of there’s on a 6060 so I can see the wires the book I have isn’t very good and by chance a part number for the correct alternator maybe Napa will have on thanks in advance
Matt |
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 800 |
delco 10si 1105423 agco # 70270085 give napa 1105423 they can cross over to there # it should plug in to the side if your plug is still there big wire goes under nut
He cut the plug off I just have wires hanging lol just have the big wire hooked up
operators manual has wiring diagram in it I don't have them any more sold the business they went with if you have a tester I can tell how to hook up the wires PM me your phone # I can till you wire to put the wires
I’ll look this afternoon and see all what I got and let you know
allis6080 ![]() Silver Level ![]() ![]() Joined: 19 Jan 2011 Location: erie Pa Points: 334 |
The plug in makes an L shape. Top of the L (closest to big orange wire)light green black stripe. Next wire down would be light green. The one closest to pulley would be brown. Brown wire goes to the tach.hope this helps.
Edited by allis6080 - 28 Jan 2019 at 3:27pm |
6060 s\n 5016
1947 JD B |
LB0442 ![]() Orange Level ![]() ![]() Joined: 27 Dec 2014 Location: Boise ID Points: 767 |
Pictures are always good. This was on the 6080 when I bought it. Tach works great.
Take the alt. you have apart, run a wire through the back and hook to one of the three terminals of stater. The other end connect to brown wire. MACK
Ok thanks for all the help guys I went and look last night after work this is what I found
The wrong alternator there no place for a plug at all the wires are still there I think I no I seen a green one it was dark they just cut the plug off so I ordered a alt now just gotta find a plug and I’ll wire it in and put the new alt on and see what happens |
The tach that runs off a single wire from the alternator is using the alternating frequency inherent in the alternator. That makes the tach calibration dependent on the number of poles in the alternator stator (and there is no industry standard for that count) and the pulley size giving a ratio from the engine crankshaft. Alternators generally spin faster than the engine, that's what makes them charge well at engine idle speed.
For the tach to work properly the alternator needs to be the factory original, any universal replacement is unlikely to have the same parameters as the factory original, but its not absolute that some universal replacement won't work correctly. Gerald J. |
any Delco alternator 3 post will work must use the right pulley
What size pulls are you guys using
AGCO # 70262155 it is a 2 grove 3 1/2 od for 1/2 in belt flat on alternator side i get mine from my repair shop
I just measured the one in the picture and it is a 3 1/4 pulley. Tach is pretty accurate with that. I checked it with a photo tach.
Ok thanks I looked at my wires I’ve got everything there just the plug is cut off new alt will be here I’m a few days and will see what happens
Hey guys sorry I haven’t updated been busy
Hooked up the new alternator and the tachs working like it should now so thanks for all the help now on to the next part of the project on it |
