Styled Allis WC stroked?
Bullermanfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bullermanfarms Quote  Post ReplyReply Direct Link To This Post Topic: Styled Allis WC stroked?
    Posted: 14 Jan 2019 at 8:33pm
Im going to try building a Allis WC for pulling and farm use. I was gonna put in a wd 45 crank, stock rods and slight cam work with flat top pistons but when i do the math I get  15 : 1 compression. I may have the math wrong but anyone got any advice to bring it down so i can still run pump gas and start it from the stock starter. Or any advice to get more power out of it.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 10:03pm
Machine top of pistons off.     MACK
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 6:28am
I put a WD 45 crank in a 1948 WC. I used WC rods and WC aluminum flat top pistons. I did extensive static compression ratio calculations. The CR calculates to just a touch under 8:1. The head has a quality valve job with ports cleaned up and seats blended into the bowl area. It'a a 12V conversion with stock 6V starter with the improved starter drive. I run a distributor with Pertronix electronic conversion with slightly heavier mechanical advance springs which is year round in Northern New England. This stretches out the advance curve to avoid ping at extreme low RPM. It runs fine on regular gas for regular chores. When I tractor pull which is rare, I run premium gas. It really wakes up a WC. I believe it gets over 50 HP. Makes the WC a lot more fun. I'd do it again in a heart beat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bullermanfarms Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 8:44am
Are you running stock manifold and carb? Any cam work done? I was gonna get some cam work done by berrys cam service in MN but DR. Allis on here is saying they're quality make have gone down due to new management
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 9:49am
Yes I'm running a stock Carb, Manifold, and Cam. A bigger carb from a D17 would help at higher RPM like when pulling a transfer sled in competition. A pulling cam would also help also, but specify to your cam grinder whether your pulling a dead sled or a transfer sled. I run a 35" overall length, 2" or 2.25" inlet and outlet glass pack muffler with a flange welded to the top of the manifold and muffler inlet. This eliminates the restrictive pipe fitted inside the exhaust manifold.  I also installed a flapper cap on top and painted the whole exhaust system Rustoleum Barbecue Black. I found it holds up better than Krylon. It sounds great and not ridiculously loud like open stack. I still wear head phones when mowing with a 6' finish mower, mostly because of the mower noise. Plowing snow etc., I find I don't need the head phones.
This page was generated in 0.071 seconds.
