190XT Injector Test
nsummers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsummers Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Injector Test
    Posted: 06 Dec 2018 at 10:09am
I'm needing to know what type of thread the injectors are on a 190xt Diesel.  Looking at buying a injector nozzle pop pressure tester to make sure my injectors are firing properly.  This tester only has adapters for thread Type A and B according to the specs and before I buy want to make sure the adapters will fit.  Any help is appreciated or if someone already is using a particular brand let me know.  Not wanting to spend a ton of money on a tester.  Thanks
Below is the link to what I'm looking at.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 10:20am
We were out in the field and thought we had a miss - did not seem valve related so we removed the drip line and injector and turned the injector upside down and connected the fuel line back - cranked the engine and observed a perfect spray pattern - turned out to be stuck rings on a piston beginning to fail - but it let us know there at that time it was not fuel related. We also have made adaptors by brazing lines to fittings for our old hand tester. Wish the new engines were that simple...
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 11:31am
Threads are 9/16" X 18 or NF, but connection is Ermeto deep bowl design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsummers Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 2:53pm
Thanks for the info, it looks like the one I'm looking at doesn't have the correct threads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 3:21pm
That one does not. It has 12mm and 14mm.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2018 at 8:51pm
$84.99
WIN.MAX Diesel Injector Nozzle Pop Pressure Tester Dual Read Bar/PSI Gauge S60H W/Filter
by WIN.MAX
Currently unavailable.
We don't know when or if this item will be back in stock.
  • The items you ordered will be shipped out in 1-2 business day from CA,USA. And you will receive it in one week.
  • initiatve injecting press of injector
  • sound of needle valve vibration
  • Brass Bourdon tube Pressure gauge - 100 mm Dial, 3/8 " BSP thread Dual Scale Gauge Range:0 - 60 Mpa & 0 - 8000 PSI (See image 2 Above)
  • High pressure pipes 'A' and 'B' type with m.m. size nuts (12 X 1.5) and (14 X 1.5) for connections
