D-14 Knob
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: D-14 Knob
    Posted: 23 Aug 2010 at 8:53pm
I just found a D-14 with a Woods RM-306. I see this large knob in the lower right hand corner on the instrument panel.  Anyone know what this does?  Not a choke or light switch, it plulls something under the fuel tank.  Thanks in advance.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2010 at 8:54pm
belt pulley engage knob
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2010 at 8:55pm
Belt pulley engagement control. If you don't have the belt pulley on the tractor and would like to sell the knob and linkage I'd be interested.
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2010 at 9:18pm
That control rod seems to be expensive - only saw one and more than I would pay. I got a cheaper PTO control rod from a WD or 45. Bend it a little, then cut center part out, over lap and weld to length. Pretty easy to do and covered up with the side panel.
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 7:32pm
Thanks Rick.  I pulled the knob out and there is a belt pulley installed there but nothing happened.  What should I look at next?  Thanks in advance.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:19pm
The crank lever for the belt pulley is made into the torque tube. If you have no pulley on the outside of the frame then there is nothing inside connecting the crank arm. It just hangs inside there. It would be nice if you couls post some pics and demintions of the linkage as I need this linkage setup.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 8:30pm
That linkage and knob setup is very simple to make,if I can find the one I have I will measure it for you guys. Thanks Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 10:27pm
There is  what appears to be a pulley on the outside.  When I pull the knob out the pulley does not turn.   Is there another step to complete?  Thanks in advance.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 11:48pm
make sure it is in the lever(if your side panels are hiding seeing it). let the clutch out.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
