CA steering problem
MikeinMadisonCo. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinMadisonCo. Quote  Post ReplyReply Direct Link To This Post Topic: CA steering problem
    Posted: 29 Aug 2010 at 11:14am
The wife's CA (wide front) has been sitting outside all summer with very little use.  I tried to move it the other day and it would not turn...like having power steering without any fluid only this does not have power steering.  We have had a ton of rain this year do you suppose water got in somewhere?  Thanks folks!
If the horse dies....get off!
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 12:03pm
Sounds like something rusted together.  I had to change the front part of mine where the steering arm goes in and the pedistal is bolted to.  It was very hard to steer and the bushings in the shaft were setting up.
Wil
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 12:04pm
 grease the spindles with the front wheels off the ground turning back&forfth while you grease check the steering box 4 water if full take the adj. screw out thats the one be hind the starter to drain flush with fuel oil refill with gear lube dont forget to check trans- rear end & Hdl. if water in trans drain them all refill motor I use 15/40 year round.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 12:29pm
Might be handy to jack it at the torque tube to unload front end and maybe tell then where its locked up.
