inter-changing front rims???
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Topic: inter-changing front rims???
    Posted: 28 Aug 2010 at 3:31pm
I need one good front rim for a D10.  I know the D10 is 15 in and the WD series is 16. My question is the bolt pattern the same to be able to put WD rims on the D10. If I can't find a good 15 in, can I put two WD rims on the front. I don't have the D10 here to try it. Sooooo, will it work, or do I go to our classifieds.   Thanks in advance,  Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 3:44pm
im guessing no. I bought two 16 inch D15 rims and tires to put on a B, which had 15 inch wheels. ( I knew the bolt pattern was not the same). It was not even close. I had to cut out the center disc and install a new one with the new pattern.  I wanted bigger heavier tires on the B.
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 4:22pm
Case SC cast front rims are 15 inch and fit the WD. If you want some extra weight up front you could go that route.
mojo/Mike
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 4:44pm
Fred, I have a set of case SC rims here if you need a set.   They have a brand new set of Firestone triribs, which I was going to put on my B.   When I went to look at them I brought a B front hub and a WD front hub to see if they would work on anything I had and they matched the B front hub perfect.   I don't think you'd ever break them things, they're heavy!!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 6:06pm
Measure the bolt pattern and the wheel center hole. Many a tractor has used 6 bolts on a 6" bolt circle. And the same rims fit many a wagon and implement. 5 bolt circles are less standardized but there is an agricultural standard, plus Ford, GM, and Chrysler where few interchange.
You have to check offset, so you don't end up with rims way too wide or tire sidewalls dragging on the spindles. Look at Baum Hydraulics (www.baumhydraulics.com), or Shoup (www.shoupparts.com) for the commonly available 5 and 6 bolt ag rims. Gemplers, Miller Tire, and Value-Bilt will also have a selection.
Gerald J.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 7:32pm
Why not just order the correct rim I know tonys tractors has them. I bought one many years ago its holding up fine.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:14pm
  we have new frt.rims   1-574-342-4545 northern ind.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 8:22pm
D10-D12 had 5 on 4-1/2 inch circle, don't recall center hole size, same as the B, C, CA.
WD, D14, D15 on larger bolt circle and center hole.  Later D15's and 17's had 6 hole pattern.
Edited by JoeO(CMO) - 28 Aug 2010 at 8:28pm
This page was generated in 0.172 seconds.
