New to me 200 new here too
maggieglide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Topic: New to me 200 new here too
    Posted: 19 Oct 2018 at 5:58pm
Excited to say I finally have bought a 200. My uncle used to have one when we were kids and I always wanted one. I am not a farmer but will use it to mow our property and restore one day. It seems to be in pretty good shape but has a few issues. Needs an alternator and tach cable. I think a few of the injectors are leaking. New seals? Washers? It seems to run well but I hear zero turbo whistle even with a wore out muffler. Anyway, glad to be here.tractor1_2018-10-19_17-56-37.jpgtractor_3.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 6:01pm
Injectors don't usually leak. It's the valve cover gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 6:18pm
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 6:28pm
    Like the Doc said it is valve cover gasket.
     John Carlson
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 6:47pm
Mine starts and runs good. I can't here any turbo while inside the cab
Good luck with her.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 7:03pm
Welcome to the forum and post more pics of the tractor. Are you around Goldsboro?
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 8:18pm
Yes I’m in Goldsboro, you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 8:25pm
North of Winston-Salem I have two 200s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 8:30pm
I replaced the alternators on both of my 200s with one wire alternators but after going through matching up the right gears for the tach drive I would recommend getting yours rebuilt if all the parts are there. Is it not charging? Or is it missing the gear drive for the tach cable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2018 at 10:26pm
Welcome to the forum. Nice tractor you have
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 6:40am
Just be aware that after the valve cover leak is repaired, it may still appear that there is a leak until the oil that leaked from the valve cover quits working it's way out from around the injectors.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 6:51am
The prettiest grill Allis ever made graced the front of 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 6:51am
The bearing sounds terrible, where can I find a rebuild kit. I haven’t found one yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 6:54am
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 6:55am
Thank you
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 4:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 4:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2018 at 11:07pm
As stated,folks think they have leaky injectors but it turns out to be cover gasket leaking into injector hole. Try it and see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2018 at 9:11pm
X3 on the replacement of the valve cover gasket. My XT was doing the same thing. A good steam cleaning will clean it up if you have one available to rent. Local dealer allows me to use his for $25. Does wonders on all that oil and grease especially with some Purple cleaner soaking for 15 minutes helps also. 200 was a good tractor. Stilll a lot of them in my area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maggieglide Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2018 at 7:43pm
Thank you for the advice. A heater power washer? I’m sure I could rent one
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2018 at 9:26pm
Steam Jenny is the common name. Too expensive to buy unless you have a large operation with lots of equipment or have a repair business.
