speedi sleeve question
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: speedi sleeve question
    Posted: 26 Sep 2018 at 4:32pm
I sleeved the front crankshaft shaft on one of my B's. I thought the seal was centered close enough but I guess not as I have a small leak. Question is-is the seal shot already or can I loosen things up and try to center it again? Will the seal get progressively worse?  I have the correct sleeve and seal. It has run maybe 20 min. It's going to be put away for the winter soon.
Edited by mdm1 - 26 Sep 2018 at 8:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 5:59pm
It you peeled the sleeve driver off the speedy sleeve, it may be too late, unless you have a piece of stock pretty close to the OD of the crankshaft.  If so, you may not even need to dis-assemble, just knock the sleeve back a bit, and see if the leak stops...Wink
On edit, I see I gots it backwards, you wanna move the seal, not the sleeve.  In that case, maybe the same answer...Wink
Edited by DiyDave - 26 Sep 2018 at 6:01pm
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 6:03pm
I left the driver on and drove it on as far as it would go. I am wondering if my problem is that the seal is not perfectly centered on the shaft. ?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 7:24pm
Very very easy to tear the seal lip installing the front cover. I started making a funnel shape with .002 shim stock over the end of the crankshaft after tearing a few seals. I made a pipe sleeve to drive the speedy sleeves on.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 8:02pm
The front timing cover on the CE engine dosent self center. I've usually been able to loosten the timing cover bolts and just wiggle it around with the crank pulley installed then tighten it up. If you tore the seal installing it it'll still leak and you'll need to put a new seal in. You should have the engine hanging from the hoist when you do this if it's sitting on the front end befor you tighten the timing cover in place it'll leak every time
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 8:30pm
I had the front end off when I did it. I will see if I can loosen the cover and try again. I guess maybe back to the drawing board for me. Thanks!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 8:52pm
When I re-sealed my engine, I had the front end off the tractor. The hole in the timing cover was too small to accept the replacement rubber lip seal, so I bored it out with a dremel tool, trying my best to keep it round. I pressed the new seal in, then filled in the voids around the edge with red Permatex. The black stuff is supposed to have max oil resistance, but red (high temp) is all I had on hand at the time. I placed the cover on the engine over the crankshaft snout and centered it best I could, just by sight, then snugged it down. I noticed it was just a hair off, but didn't worry too much. That was all in 2015, and it's been perfectly dry since.
I didn't put a Speedi-Sleeve on mine, I took some advice from a forum member and used JB Weld to fill in the spiral. I just cleaned out the groove with a toothpick and some solvent, applied the JB Weld, let it cure, then sanded/filed it down to be flush with the shaft. Some may say the JB Weld will wear down over time and cause a leak, but the seal rides on the steel, not the JB Weld itself.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 6:22am
First thing to do is determine exactly where the leak is coming from instead of blaming the seal. If you have already done that greatWink  but front end leaks can also be between the seal and cover,  Between the speedy sleeve and shaft. Cover gasket and oil pan gasket.
Not a model B subject but I fixed many W201 "rear seal leaks"  over the years for frustrated owners. Some of them had replaced the seal several times. Half the time it was the oil pan installed wrong, other times it was from not installing the little gaskets or sealer under the rear main cap.
Always install the seal after installing and centering the cover. I made up a cone to center the cover but not having one of those  you can use the seal to eyeball the location by sliding it on the shaft next to the cover. It is pretty easy to see if the cover needs to move to center it. Goodluck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 7:01am
Butch you are 100% correct. My first rebuilds of these engines were front end leakers and I learned to clean and seal with silicone between the bottom of the bottom of the front cover and block as can be seen in this picture.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 7:23am
It is leaking at the shaft. But I did install the seal in the cover first and the put the cover on. Trying to figure if I did anything right. Man. I do appreciate all the help.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 9:12am
Do either of you guys have a picture or diagram for the seal centering cone or the crank end funnel that is spoken of ???
wfmurray View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 1:10pm
  Dick L Seeing your picture of an oil pan reminds me of what dad used to do.He used sewing  thread and tied the gasket on .Can leave thread on if you want it will press in gasket.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 2:01pm
An old (now deceased) neighbor mechanic used fish line. I took apart an engine that he overhauled and the fish line was still on some of the gaskets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 5:03pm
I used string years before I ever thought of taking pictures and using silicone. Close pins are much quicker and easier for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 8:49am
To line the cover with the original A-C tool, you remove the seal from the cover and install the cover loosely on the engine. You then slide the tool over the shaft and it centers the hole in the cover to the shaft. Tighten the cover bolts, install the seal last. Years ago when I overhauled my CA and noticed there were no dowels to line up the cover, I installed the seal in the cover first, stood the engine up on the flywheel, and installed the cover using a feeler gauge to gently lift the seal lip over the shaft. It's dry some 20 years later.
