CA grader blade
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA grader blade
    Posted: 06 Sep 2018 at 8:59pm
Was there a mid mount grader blade made by Allis Chalmers for a CA?
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 11:39am
I'm pretty sure the answer is no.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 11:55am
There is not one listed in the CA brochure. Its not something that would have been used on a farm back when these were made. I have built two for C Allis's and it wouldn't be hard to build one for a CA. The easiest would be a 3pt adapter and back blade. a belly blade works much better. the two I built I got free discard grader blade edges and run push arms back to the Plow mount brackets and used just hand levers and cables to operate. one of the push arms needs to have a swivel built into it or you cant change the leveling. I angled to the right by having a shorter push arm on that side and it was non adjustable. a belly blade works very nice for leveling and shaping since its between the tires it shaves the high points and fills the low points.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 4:05pm
I agree with RMD.  Nothing from the factory was made by Allis-Chalmers for the CA.
That said, there may be homemade attempts.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 4:59pm
Copy the one that IH had on the cubs.--It will go front OR belly. I use mine under more than out front.---Makes nice light small grader. thanks; ac fleet
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2018 at 8:00pm
I saved these pictures from the Go-To in New York several years ago!
Do not know who's the owner or builder, but Very interesting to me!
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 6:10am
there's a guy up here on Kijiji ( cdn CL..) that took a 416 rider and converted to roadgrader, wanted $1800 I think. kinda rough around the edges but it worked as it should ! IF I had a real use for it, i'd have bought.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2018 at 9:24am
Inherited my dads 1948 Farmall Cub with a 54A blade which can be mid mounted or front mounted. I plowed a lot of snow with it growing up. It was the first tractor I drove. I was hoping there was a similar grader blade made for a CA. Thanks, Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2018 at 6:23pm
