D15 hitch control valve
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Topic: D15 hitch control valve
    Posted: 26 Aug 2018 at 7:44am
I bought a cheap loader for my d15, and got it put on, but what i found is that i can't lower the loader without first lowering the rear blade. I thought that the knob on the outlet on the rear of the tractor was supposed to hold the rear hitch up. It doesn't do anything, threaded in or out. Was i wrong, or do i have something not working right inside that valve? I was planning on selling it this fall as a complete setup for someone to clear snow, but as it sits, its kind of a useless setup.
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2018 at 11:10pm
You need a valve that "Switches" between the front and rear hydraulics.  On my 15II, I can only use the loader, or the rear lift, switching between the two as needed.  Seems like the hydraulics are a bit limited on these tractors, unless you go all out like Dr.Allis did on his!
D15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2018 at 4:48am
The loader can be disabled, by installing a simple gate valve, in the single line,  that goes to the 2 loader cylinders.  Tractor hydraulics are just doing what they were designed to do.  that means lift arms lift first, then the remote cyl lifts.  On the drop, the remote drops first, then the lift arms drop. System was designed for plows or discs, loader, not so much...Wink
