7010 Engine Surge?
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Engine Surge?
    Posted: 14 Aug 2018 at 3:38pm
My 7010PD (with an L-Combine Simms Injection Pump) started surging today.  I am a novice with Diesel engines.
Any common issues that cause this?  It is really noticeable at low to mid RPM with the tractor stopped ( no engine load)
I just replaced the fuel filter and installed a new turbo.  The air filter looks ok and I cleaned it out about 10 engine hrs ago.
It does not overheat and I can see any thing out of order.
I put the turbo and new filter on at 5100 engine hours and it has 5120 hours now.
Thanks,
Roscoe.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 5:23pm
I have a 426 On Highway Spec engine with a Simms pump in my 220. It will surge at a slow idle. Crack the throttle a little and it smooths out. I'm sure it's the governor.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 7:51pm
I've got a 7000 that runs with a lope at low rpm but it has almost double the hours. So that could be expected?
At 5000 hours it should still run smooth.   I would suspect the governor...check valve...fuel line...hose clamp..or any fitting in-between. Does everything look clean?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2018 at 9:51pm
The Simms pump on a combine would about shake the combine apart.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 4:09am
 I will check all the fittings this morning.  The #1 outlet fitting on the pump does look wet.
This surging is new, it just started, so this is not normal.
But most likely a pump or fuel problem, and not a turbo or air problem?
Thanks!
Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 6:36pm
Get it all rebuilt ! No problems then
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2018 at 10:29pm
Govenors in Simms pumps are known to wear and cause issues like you describe. My 545B loader w/301 has it and  surges at idle. If you ever seen the govenor you'd just shake your head.
This page was generated in 0.227 seconds.
