Allis Chalmers unstyled wf
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers unstyled wf
    Posted: 22 Jul 2018 at 7:15am
Looking to possibly getting a 37 wf serial number 142. Has no tires missing radiator and hood. Everything else appears to be there. Motor turns over. My biggest question is what parts will and won't fit from a unstyled wc. Any help would be greatly appreciated thanks
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 4:45pm
Not sure if the sheet metal would be a direct fit? I measured the hood on my 1937 unstyled WC. The hood measures 36"L x 22"W. Hope this helps.
Edited by BEK - 22 Jul 2018 at 4:49pm
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 5:23pm
Thank you. I'm currently working on a deal with the guy. Needs a lot of work but the motor is free and the block hasn't been repaired so it's going to be a fun project. Did the 37s come with spoked wheels on the rear or no? It has what's left of spoked wheels on it now. If it's correct I'll probably try and find another set
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 6:24pm
Hood and rad are interchangeable with unstyled WC,  Spoke wheels were used up to past that number, I had WF502 and it had spoked wheels.  Many parts are WF specific.  Mine had bad fenders but I had a bodyshop friend use the fenders off a WC and cut them down and refit them to the inner pannel from the WF. Steering wheel is different on the WF as well as the rest of the steering components including axle hubs and front wheels. Seat and backrest are same as Wc but the support spring is shorter (not interchangeable).  Other parts also just can't remember now, HTH's
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 6:57pm
Good luck and hope you close the deal. You are taking on a challenge but the folks here are a big help. When you start playing with these old tractors it can be frustrating, but when it turns out right it's rewarding.
I just rebuilt the Zenith 124 1/2 carburetor on my 37 WC. I had to order a few more parts than what was included in the rebuild kit. Sometimes I feel like I'm shooting in the dark when ordering parts or working on this tractor, but it has turned out well.
Please post some pics of the WF if you get it!
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 8:31pm
Round spoke 24 inch rear wheels would be correct unless they are flat spokes. Then that would suggest that they were cut-down steel wheels. The sheet metal should interchange with a WC except for the rear fenders.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
Rog NCWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog NCWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2018 at 9:34pm
According to Allis-Chalmers data book, (page 47) the rear wheels had 24 inch tires and round spoke-type prior to serial number 204. From serial number 204-1903 they were disc-style wheels
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 6:23am
Thanks for all of the replies. Awesome information
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 6:49am
The hitch is not the same. Just assembled sn 9xx and11xx using WC parts. Sounds like all you need will be a WC doner.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2018 at 2:31pm
My number is 207 431 9826 if someone could be kind enough to post pictures of it for me
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 10:48pm
Also does anyone know where I can get front rims?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2018 at 6:51am
DJS tractor parts has front rims
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2018 at 7:36am
Thank you
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2018 at 10:01pm
Good luck with your WF project!  I own WF#13.  Sam Parker from North Carolina & Florida owns WF#9.  Please let us know how your project goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 7:30am
Good luck with your project! I know nothing about the WF! So I will not be much value other than a cheerleader on the sidelines! it looks like there a bunch of folks that will help you along the way. A free turning engine is a good thing!
Maybe you will help me continue to move along on my own project too. Looking forward to following your progress! Get it home!
This page was generated in 0.281 seconds.
