old gas
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: old gas
    Posted: 20 Aug 2010 at 11:15am
I pumped about 8 gallons of 4 year old 110 octane out of my Camaro(finally driving it again, have to go get a haircut..)
  Some tell me it does not go bad, other say make weed killer. It smells OK. I will put in glass and see if it separates.
  If it is bad, will the JD G burn it OK ? or my 45? the G is a strong fresh engine.
  mix it 50/50 ?
thanks,Larry
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 11:38am
Put it in the JD G that way if it hurts anything it will be a laughing matter, LOL
With a dozen tractors around here and most dont see a lot of use I have gotten used to that bad smell when I remove a gas cap and as long as it isnt too bad we run it with seemingly no affect. if it REALY smells bad we use it like roundup, away from the well of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 12:00pm
this has no smell, does racing gas go bad in a different way ?
Dad's G is worth 2 of mine though !!!
2014 HD Tri Glide
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 2:54pm
Easiest thing to do with old gas is just mix it with fresh and you'll be to go. I would bet 50/50 would be just fine.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 7:28pm
I have been running it in my Z turn Kawaski lawn mower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 8:36pm
the gas may be old but might still work in lower compression engine. The new formulated gas with the oxygenated additives will last 30 days or so at full additive strength but sours real fast after that.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 9:09pm
In my experience, the higher octane gasolines seem to go much longer before turning to varnish. Some cheap gas will turn to varnish in just a few months given the right storage conditions, but I've seen 100LL Avgas be apparently fine after five years of storage in a full, tightly sealed can that has been kept in a cool dry place.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 10:22pm
If it had ethanol in it, I wouldn't use it. But if it's straight gas, which if it's 4 years old it should be, whats wrong with using it if it doesnt separate?
This page was generated in 0.032 seconds.
