5015 |
AllisandGleaner
Topic: 5015Posted: 19 Jun 2016 at 4:34pm |
Looking to buy a 5015 with a belly mower and I wanted to know the transmission gear speeds anyone know what the speeds are thanks.
irlbeck A-C'S
Joined: 28 Sep 2009 Location: Crestview FL. Points: 689 |
Posted: 19 Jun 2016 at 5:38pm |
![]() It can go slow, real slow, and really really slow.LoL Tires can adjust the speeds a little. It appears top speed is 7.7 mph and goes down to a snails pace. |
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3122 |
Posted: 19 Jun 2016 at 8:19pm |
They can go very slow,I have a MF 220 which is about the same as the AC 5030 and don't use the lowest range even when I run the rototiller with it.Handy tractors down side
is there is No parts support. |
AllisandGleaner
Posted: 19 Jun 2016 at 8:41pm |
Thanks looks like 2nd in high is the mowing speed
GARY(OH/IN)
Joined: 19 May 2010 Location: Findlay,Ohio Points: 917 |
Posted: 21 Jun 2016 at 10:55pm |
Yes 2nd in high at about 2500 RPM is what I run 2 different 4' bush hogs and a 5' finish mower if your grass isn't too heavy.
I have a manual for the 1582 3 blade 54" belly mower. Some mouse damage on front lower left cover, doesn't effect info. $5+ $2 postage. |
timac5015
Posted: 09 Jul 2018 at 9:50pm |
why wont my 5015 start right up with new battery still needs a jump
I think the ccamps is 585 but I hit the glow plugs 5-7 seconds then nothing not even a click charged by truck it will eventually start right up and sound like a Porsche functions great when running I use it in the snow with 6 ft blade and cylinder lift but I got to be able to depend on it how long should block heater be on before planned use? great forum any advice thanx guys |
timac5015
Posted: 09 Jul 2018 at 9:51pm |
AM I NOT GIVING THE PLUGS ENOUGH TIME TO HEAT?
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54679 |
Posted: 10 Jul 2018 at 4:38am |
If it is like most Japanese tractors of that era, I think the pre-heat time is 30-45 seconds. Also check the buss bar, that connects the gp's together. it sometimes gets loose, on the gp's, and doesn't connect...
