WD45 Loader Cylinder Help
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Loader Cylinder Help
    Posted: 07 Jul 2018 at 10:35am
Is there new seals available for these? Can a couple wrenches and elbow grease rebuild these or do I need to take them to a shop?
Anyone have a part number for the seals or know where to get them? These drool and slobber like 12 month old baby.
Edited by AJ - 07 Jul 2018 at 10:36am
Can't fix stupid
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 10:46am
They are Freeman (part of Allied farm equipment) parts, if that helps....
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 11:16am
I'd take those to a hydraulic shop and get them polished anyway. Let them fix it all.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 11:22am
Mine is a Freeman of another style and I pulled the rod to take to the seal business to get an exact fit here in OKC.
If you have the funds available, I'm with Doug.
Edited by Jim Hancock - 07 Jul 2018 at 11:23am
How blessed we are by HIS GRACE!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 11:55am
Loader does have a WD9 tag on it if that make any difference.
Edited by AJ - 07 Jul 2018 at 11:56am
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 11:57am
Anyone have any idea what having them done by a shop might cost as to me buying the seals and doing it myself?
Can't fix stupid
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 12:05pm
I got a set from Agco couple years ago
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 3:20pm
Uup shop wanted $400 to refurb 2 cylinders, I did it for $30 worth of parts. That was 8 years ago,worked real nice. 4 days ago I hauled them to the scrap yard with the rest of the loader. I had ZERO interest in them for 90 days.Nada,zip,zilch..I'd have given them away to any tractor guy. Also took a whack of cylinders from a car carrier and a section of 1.25 bar stock 10' long with a bunch of #80 sprockets and bearings on it. Only 10 cents a pound but made some room and filled the truck with $5.50 /gal gas.
Sorry guys but I can't keep everything forever and shipping 'south of the 49th' is $$$ .
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:11pm
I rebuilt both mine with$24 for two seal kits from AGCO. Took pictures and put part numbers in post you should be able to find it. Unless the cylinder has b en laying in the dirt 10 minutes with some fine Emory cloth and transmition fluid will polish them right up. It only takes a large pipe wrench a wrench for the bolts and a screwdriver to get the stop ring off the end. The second tractor I did it took me 30 minutes from start to finish. Use a pipe wrench and loosten the end cap before taking the cylinder off the tractor
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:20pm
How smooth are the shafts? If pitted check out what Surpus Center has. Could be cheaper to replace the whole cylinder.
Just worked on my JD 1250 and JD sold seals in kit form $60 a cylinder. But didn't look right in the plastic so visited the local bearing and hydraulic shop $30 bucks for everything but the piston seals as they didn't have that. No oil pouring out but now settles much faster than before. So one of those work on it twice things. But I tried the ordering parts before taking it apart way with no luck besides having to pay a restocking few to get rid of the wrong parts. I know Shameless poke away.
So with time and helpful store you should be able to find parts.
Edited by Ray54 - 07 Jul 2018 at 6:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:22pm
The last cylinder I rebuilt was a remote for the WD45. The packing cost me about $8 The rod was bad on it so it cost me another $20 for some chrome shaft and a couple hours in the shop to cut me a new rod out of the shaft.
Edited by CTuckerNWIL - 07 Jul 2018 at 6:23pm
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 6:33pm
Dave do you happen to have the part number for the kits. My local deal wants to sell me individual pieces at $7.50 each. I figured surely there's a kits for these things.
Edited by AJ - 07 Jul 2018 at 7:31pm
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 10:33pm
I wouldn't have a clue about part numbers. Find a Motion Industries near you and bring the old packing with or measure the rod and the bore of the packing gland.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 4:59am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 5:47am
On a one way cylinder it doesn't matter if the shaft is smooth or not as it doesn't hold oil back,if there is oil coming by the shaft it means the packing on the cylinder rod is bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 7:53am
Wrong.   On this cylinder, there is no piston on the bottom of the rod. The rod itself is the piston, so smoothness of the rod is important. All there is at the bottom is a snap ring that keeps the rod from pushing itself right out the top.
Edited by TramwayGuy - 08 Jul 2018 at 7:53am
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 7:54am
the rod has to be smooth there is no piston. go to hyd shop for packing that is what I do   the price is  better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 8:54am
I can't see how the fluid can come past  the base of the cylinder and still be able to push the cylinder rod forward.Where does the fluid go when the cylinder comes up and the rod pushes out? No holes or return on that end of the rod base. And what pushes the rod out in the first place? If the fluid can get between the base of the rod and the barrel the rod isn't going anywhere.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 9:21am
If you look at the pic showing the breakdown of the loader's cylinders, the WD-9 loader cyl's are about the same as WD tractor used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 9:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 9:41am
Fluid does not compress. When you put fluid, under pressure, into a single acting cylinder, something has to give. The rod is the only thing free to move.
http://www.modernhydraulics.net/images/hydes/uploads/2011/01/single-acting-cylinder.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 12:18pm
all the lift cylinders on allis from about 1940 until d17 s 4 where that way on the lift arms
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 1:08pm
I was able to get one apart last night guys. It was actually pretty easy with the biggest pipe wrench I have and my chain binder cheater bar. Have completely disassembled the ram assembly and plan to clean things up to rebuild it. I will post pics soon.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 1:09pm
If anyone has the kit part number for AGCO that would be helpful.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 1:49pm
72000064 was kit  now agco sells 72000650 seals only takes 4
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 2:49pm
For what it is worth, I "rebuilt" mine on the tractor. I packet it with some sort of rope packing my neighbor gave me for the purpose. Probably not AC, but generic instead, I'd check around with hydraulic shops. I do not know where he got it, but I will ask when I get a chance. cut the rope seal a bit longer than the circumference, cut the ends for a nice scarf joint. Cleaned up the shaft a bit with emery cloth (and mine was worse than yours!). Just make sure you 'walk' the seal flange down evenly, stuffing the rope in with a blunt screwdriver as you go. I never had a problem with leaking afterwards, even as bad as mine were. I doubt both cylinders took me more than 45mins to an hour
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 2:52pm
BTW, I have repacked two sets, one set had the 'W' seals in them, the other had the rope packing as I described above
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 2:58pm
http://allischalmers.com/forum/freeman-w9-loader-cylinder-overhaul_topic149366_post1241269.html?KW=Dakota+Dave#1241269 Seal package is in pictures.
The AGCO seals are leather chevron packings . They will seal on less than perfect rods. Just oil the rod and rub with some fine emery cloth.
Edited by Dakota Dave - 08 Jul 2018 at 3:20pm
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 7:41am
I bought my seals from a place that advertises here. Sandy Lake Implement. Takes 4 per cyl. I've done 2 sets now. One thing. Polish those rods till they shine like a mirror. Otherwise you're seals will go bad after a while.
Steve Zidlicky View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve Zidlicky Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 10:38pm
yarbrough industries Springfield mo  417 869 5344 will have your seals. do not go by loader model just measure shaft size.  I would polish those shafts real well before ordering parts from anywhere.  they will not have the air cleaner hose
