LED on Pos ground?
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Topic: LED on Pos ground?
    Posted: 19 Jun 2018 at 7:19am
Ok guys.... so I am looking for another opinion, I guess. Can I wire LED lights into a positive ground tractor? I think that i should be able to, as long as I just hook it up so that the positive side of the light is connected to the 'ground'.... right?
(I am wiring a (gasp! OuchConfusedBig smileLOL) JD 630 for a friend, and I was thinking about replacing some of the rusted lights with LED as opposed to original, but I figured that I should make sure that it will work before I ask him and see what he wants.... )
Thanks!
Ben
'39 Model B
Tractors are cheaper than girls, remember that!
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 7:24am
As long as the led light has two wires and you observe the positive voltage going to the positive wire on the light so if you have a positive ground on the tractor you connect the positive wire on the light to the frame ground on the tractor.  You should be good.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 7:28am
That's kinda what I thought...thanks for second opinion, much appreciated.
I did some looking around and confused myself, but I just realized a moment ago that they were talking about putting a LED 1157 (or whatever) into a socket with a pos ground, it wouldn't work.
~ Ben
'39 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 7:39am
OK, one option that will work, is to 'float' the light base. If you electrically isolate the metal base THEN you can run LEDs on a +ve gnd tractor. I use 1/2" 'plastic' though rubber works fine. The 'trick' is to be sure the light base doesn't connect to the tractor.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2018 at 9:03am
Jay
Good idea... If I ever need to run a LED into a base I will have to try that.
Thanks,
Ben
'39 Model B
