160 Fuel Lines
Flyer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Topic: 160 Fuel Lines
    Posted: 07 Jun 2018 at 2:44pm
So it would appear that a couple of the fuel lines for the One-Sixty are made of unobtainium.  Only one of  the three hoses is available from AGCO and the going rate for it is $270.00.  I'm not sure but $100/ft seems a little extreme.
I talked to a local shop today about making new lines but they can't re-use the fittings on the old lines and don't have source for new fittings.  Anybody have any suggestions for who to contact for assembling new fuel lines for this tractor?
Tractor is an early One-Sixty (1970 Model) with a Perkins AD3.152 engine.
Any help would be greatly appreciated.
An optimist sees the glass as half full. The pessimist sees the glass as half empty. The engineer sees a glass with double the required capacity.
wigtrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wigtrain Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 3:50pm
Try any marine dealer that services the Perkins engines. That engine was widely used in marine applications. Many of the fittings and lines are the same. Plus most are metric. If you are talking about the lines from the injector pump to the injectors either go marine or Wengers in PA. they usually have good used ones. That's where I purchased a replacement.
Jim Wiggin
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 4:08pm
The lines from the injector pump to the injectors are fine.  I'm trying to replace the flexible lines from the tank to the injector pump, air intake heater, and the fuel return line.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 4:26pm
Remove band form hose at fitting ,pull hose off ,you will a nipple end to slide a new hose on , clamp with regular clamps
nonetheless ,still dead.
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 4:39pm
Keep looking for Hose shops. I took mine to them and they cut my ends off and welded it to new fittings to screw hoses on. Then made the new hose for it. Was not too expensive.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 7:19pm
^I'll make a call or three tomorrow to see what I can find.  Upon closer inspection, it looks like two of the three hoses will come apart as Fred described.  I think the connection to the banjo fitting at the fuel tank and the connection at the lift pump may require a little more research.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2018 at 8:26pm
Call Stacey at Williams in Charlotte MI. I UPS him mine they took them to a local shop and shipped them back. Can’t remember price but it was reasonable.
