7040 range cable replacement???
acnh210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Topic: 7040 range cable replacement???
    Posted: 03 May 2018 at 9:42pm
I've started to replace the range cable on my 7040. I've got the console end under control but how do you get to that illusive ubolt that holds the cable under the cab? It's a powershift with 3 remotes and has right hand fuel tank set on 30's. Everything is in the way. I appreciate any help.
Terra Tiger, WD, 7040ps, 8050 with westendorf loader, 8050ps fwa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 10:01pm
Reach around the hydraulic valve stack and remove any flow controls that are there. Now, remove the two 1/2' bolts (3/4" wrench) that hold the U-bolt bracket. I always use a long 3/8" drive extension and a wobble socket to remove the U-bolt. You might be able to slide it forward to access from inside the cab floor.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 10:15pm
Just fixed mine on 7050 today. Put a lever through floor. Like it better than lever in console.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 10:16pm
I always figured the "prototype" 7030/7050 had exactly that....a second shifter thru the floor.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 6:11pm
How about a picture Mack?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 7:18pm
I'm trying to envision a lever coming up 4 inches thru the floor and laying near horizontal under the seat and coming out near the front of the console like an auxiliary transmission shifter on a dump truck ??  There's not much room between the seat and the console for an extra lever.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 9:31pm
It's like Dr said. Low enough to swing under leg to go in park. Every thing backwards from console shift. Used a round plate with carpet glued to it that moves with shifter to seal hole in floor.      MACK
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 9:33pm
I seen a 7030 at an auction with a range shifter through the floor,, I'm sure the cable broke and this is how it was 'fixed',,worked ok I guess,,, I just couldn't figure out where Park was...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 9:48pm
Park is to left and forward.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote acnh210 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2018 at 12:07pm
I got the new cable put in about 2am this morning. I couldn't see those bolts back there. Even had a psrts breakdown and didn't catch it. Thanks for your time and help.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 8:27pm
This is how i did it on my 7030. Not perfect but quick and simple
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 8:30pm
I thought it was a little classier than how this 7030 had been fixed by the previous owner but i guess it still got the job done
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 10:50pm
that is very similar to the 7030 I seen sell at an auction a few years ago, cept they had put a truck shifter boot on it,, that sorta made it look a little more professional...
This page was generated in 0.842 seconds.
