WC Serial Number
SteelworkerND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteelworkerND Quote  Post ReplyReply Direct Link To This Post Topic: WC Serial Number
    Posted: 29 Apr 2018 at 6:38am
Good Morning everyone,
 I Just Bought a AC Model WC Tractor SN# 74328, The Tractor is Partially Styled, Styling didn't begin until 74330... Any Info? My Engine Number is W25773K  What can Anyone tell me about this tractor?? I Paid $200, The rear rims are Cast Centers, Steel Rims, fronts are Pressed steel, Some say that the sheet metal has been changed, But i dont know. Anyone else have Actual Info about this tractors & the #'s? without Personal opinion or guessing??
Thank you,
     David Sall    Winger MN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 6:59am
If the chassis s/n is 74000.....the engine s/n should be more than 74000, as there was always more engines built (for other things) than tractors. Engine or rear axle has been changed out.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 7:08am
Its a nearly 80 year old tractor.  Who knows what has been done to it to keep it going.  On a side note, it is interesting to have one with a serial number so close to the unstyled/styled changeover.
AaronSEIA
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 7:15am
What fenders and fender support does yours have?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 8:24am
Hi David
Welcome to the Allis Chalmers Forum. Lots of good info available here.
All you have to do is ask.
There is a Serial Number Reference section on this Forum.
WC were built from 1933 to 1948. Yours would be a 1938.
Also there is an Owner Registry on this Forum for AC Tractors by Model Number.
There are 738 WC presently registered.
Here is a link to some Specs. on the WC:
http://www.tractordata.com/farm-tractors/000/0/0/9-allis-chalmers-wc.html
Gary
That Engine Serial falls in the 1936 era range
http://wsmth.people.clemson.edu/SNFind/esn_tsn4.htm
Edited by Gary - 29 Apr 2018 at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 8:38am
That engine is from a 36 model tractor.
Year Tractor SN Range Engine SN Range
1933 1 - 28 (inconclusive)
1934 29 - 3126 (inconclusive)
1935 3127 - 13869 (inconclusive) - 14083
1936 13870 - 31783 14084 - 32696
1937 31784 - 60789 32697 - 62833
1938 60790 - 74329 62834 - 74893
1938 74330 - 75215 74894 - 75927
1939 75216 - 91533 75928 - 94965
1940 91534 - 103516 94965 - 108945
1941 103517 - 114533 108946 - 121799
1942 114534 - 123170 121800 - 131875
1943 123171 - 127641 131876 - 137092
1944 127642 - 134623 137093 - 145238
1945 134624 - 148090 145239 - 160950
1946 148091 - 152844 160951 - 166496
1947 152845 - 170173 166497 - 186714
1948 170174 - 178202 186715 - 196081
Edited by CTuckerNWIL - 29 Apr 2018 at 8:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2018 at 8:42am
If this is the one  that was pictured on facebook, it has definitely been "put together". The gas tank supports and engine are from an unstyled tractor. The Tractor number is an unstyled number . The sheet metal and rear wheels are from  a styled tactor.
