D12 Series 3 issue |
irlbeck A-C'S ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Crestview FL. Points: 689 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Apr 2018 at 7:15pm |
When I started the tractor it went full throttle. I shut off the engine. While I was checking linkages I found that the throttle shaft was able to pull out of the side of the carb. This is what I found. The heads of the screws sheared off.
![]() ![]() Throtttle plate is gone. I pulled the manifold and could not locate it. Looks like I'll be pulling the head off. ![]() |
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6417 |
Pulling the head is a smart move. Try to find the two screw heads while you are in there also. Let us know how far in everything went.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4959 |
The heads of the screws have most likely blown away into oblivion. You may or may not find the butterfly.
johnkc ![]() Orange Level ![]() Joined: 22 Sep 2009 Location: KCMO Points: 724 |
That can make guy say Dammit
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
first place I would check is the manifold and the top of the intake valve to see if it's stuck there.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53515 |
I'd pull the manifold, and see if its up there, somewhere...
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
I dropped 1 tiny carb screw into a F250 motor and it grenaded the piston. Good luck!
Couldn't find anything in the manifold or in the valves. I may try to run a scope in the spark plug holes this afternoon. Don't want to take a chance and mess something up so I'll be pulling the head.
Going to need a head/manifold gasket set as well as a butterfly for the carb. at a minimum. Will probably order them now but may wait to see if I can pick them up from a vendor at the Goto in Gray. |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3820 |
might be a good time to get the head done before its wore right out anyway. or at least vaccuum test test the valves to see how well there seating
Pulled off the head. Found a tiny piece of brass in the #3 cylinder. Looks like it may be one of the screw heads. No sign of the butterfly. Everything looks good. No damage to anything. Just need to get a new butterfly and it will be back running soon.
