Best black muffler paint?
Brian(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian(Va) Quote  Post ReplyReply Direct Link To This Post Topic: Best black muffler paint?
    Posted: 21 Mar 2018 at 5:15pm
Needing to paint muffler on my 170 and D15, what is the best black paint for this? Thanks
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 6:34pm
There is hi temp paint good to 2000 degrees. I think VHT is the brand I have used on headers and mufflers.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 6:52pm
vht,  one muffler one full can of paint but it stays on.      if there is somthing better that can be done in the shop i would like to know
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 7:33pm
VHT.  Carefully follow the curing instructions after you paint your muffler.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 8:07pm
Good heavens go to Lowes and buy some black grill paint. I did that years ago and still look good on my 6080.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2018 at 8:39pm
I have a spray can of Ace Hardware Heat Resistant Paint. It says good for grills, muffler stacks, and manifolds among other things. Supposed to withstand 800 degrees F continuously and up to 1000 degrees F intermittently. Part number 17188, bar code says 17188 brown. I presume they have black, I want to use this to add details to a fiberglass door where the sun through a storm door has burned the paint off. Its dark brown.
12 ounce spray can says it covers 15 to 20 square feet.
Gerald J.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 12:02pm
I have tried several special exhaust paints. I now use Rust-Oleum "High Heat", for Grills and Wood stoves, lasts far longer than anything else I have used.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 12:44pm
What MR. Becker said...
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 12:51pm
What Rick said.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 2:09pm
This ought to get a rise out of Shameless, but JD probably can't be beat, both heat and durability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 4:44pm
At the local hardware store I did see Rustoleum high heat in brush and spray can this afternoon.
Gerald J.
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:34pm
wrecker, rick, stan & me.  rustoleum.
I found it best to bring it up to operating temp for a short time first time - seems to sorta "set" it.
but then again, that might just be a subjective observation.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:41pm
The instructions on the Ace spray can suggested setting the paint without getting as hot as it is supposed to withstand the first time.
Gerald J.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2018 at 8:54pm
I'll second the JD black hi-temp paint, it's great stuff!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2018 at 9:57am
all the barbequee paint and rustoulim  last a little while used that stuff for years  hook the diggers to it for five minets or in the rain working a little its gone .    you can get vht from any parts store .   we used rustolem barbequee black on the headers on my buddes pulling truck it was gone the first pull used the vht the last two years  and has not burned at all.    i will try any brand or kind at least once  ,     every tractor that leaves our shop that has had the hood off gets the pipe painted and straightened  because it seems like a lot come with a crooked pipe .   so it leaves black or silver and straight  and know that my customers like that little extra
