175 hydraulic pressure
Josh in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Topic: 175 hydraulic pressure
    Posted: 25 Feb 2018 at 2:34pm
How much hydraulic pressure does a 175 have? I want to run a rake and Tedder That take 2100 psi.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 5:54pm
Not sure on 175 but on a 170.. The remotes have a rated maximum output of 10 GPM  and 2250 - 2350 PSI @ 1800 rpm to them.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 10:06pm
GPM is your biggest concern.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 9:06am
If you don't have a hydraulic oil cooler ahead of the radiator, cooling may also be a problem after about 30 to 60 minutes on a hot day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2018 at 12:32pm
Both are pto driven. I just need the hydraulics to pick them up.
