spin out rims
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Topic: spin out rims
    Posted: 19 Feb 2018 at 6:49pm
 Was warm today so I started tinkering and started adjusting the wheel base on the Family's wd45.  Has new spinout rims but they have never been adjusted in the last 10 years.  Anyway, got it to adjust but I am having trouble with the rims staying locked in the preferred distance.  Any Ideas?  Any comments appreciated.  Thanks,  Steve
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 6:53pm
The eccentrics have to be tightened up all the way.  Might need to put a pipe on the end of the socket.  Also put the wheel locks back on the rail which has the holes - 2 on each rail.
j.w.freck View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2018 at 6:57pm
jack up the wheel,place the lock to be removed at the top,remove the locks 2 bolts holding it on,remove lock,soak in penetrating oil remove the snap ring on the lock drive it out,buff it up and use some anti seize compound and reinstall.i have overhauled 10 or 11 sets this way.....
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 6:35pm
Thank You or both responses.  I have all but two tightened down .  So I have everything soaking and will work on them this week end.  I will need to get new tires some time this year and will break everything down and give them a proper cleaning.  Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 10:50pm
Steve, you loosen them from the top down and you tighten them from the bottom up.
As JW says, use some anti-sieze, but do so SPARINGLY!!  DO NOT get any on the square lock pin.  That will REALLY make it slip on the rail.
There's a sure fire way to get them cleaned up when they have sat for years and get all rusted up.  I've got a tutorial on here somewhere that tells it in detail.  I'll see if I can find it
When you are tightening them, you need to go completely over so the stop is touching.  You can't have them loose at all.  Good luck and if you need any further assistance, just PM me and I'll give you my cell number and help you out.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2018 at 10:54pm
Found this:
Jack up the rear of the tractor.  BLOCK it up so that it can't fall over!!
Are the tires LOADED?  This has to be dealt with or be VERY careful when moving the tire!
Take out the two bolts (carriage) that hold EACH eccentric in place.  That means you have to take out 8 bolts on each side and then proceed as follows.
Try to take the tire and rim off the tractor.  Hopefully the eccentrics will fall off the wheel.  This might take some persuasion.....I had to use a pry bar under the eccentric to get it to come loose from the wheel.  They were rusted together.  Took some beating on my part!
Try to slide the whole clamp off the rail and hope that it isn't rusted in place!!  If it is, you'll have to beat that off also.
NOW, like Cal says..... "by putting the whole assembly in hot coals of the wood stove at night. By morning take them out and rust us gone and they turn freely, does not seem to affect the hardening or the life of them. Cal in Ct"  Or just start a fire outside in a pit, like a camping fire, and forget them till tomorrow.  They DO fall apart after that.  There is a 'snap ring' holding the eccentric pin into the assembly.  BE VERY CAREFUL taking that off as you can't find them any more.  Just two (old) screwdrivers working to get it up and off.
Now just tap out the eccentric pin.  It is what everyone refers to as the bolt, but it isn't a bolt.  It has the tab on it that allows it to spin back and forth between tight and loose.
Now just clean them up.  Knock out all the rust and then wire brush them.  Or better yet, if you have access to a sandblaster, it will be a lot easier.
Now put anti--sieze on the eccentric bolt and the bolts/nuts that hold the assembly in place and the back side of the assembly.  You probably won't need to take them off again in your lifetime, but it'll make it easier for the next guy.
Don't get any anti-sieze on the rim lock wedges!  On the face that goes against the rim rail.  They tend to slip then.
Hope this helps....There are several threads on here for doing this, all you need to do is search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 4:46am
If the rails on the wheel are worn, sometimes you can put a shim, between the square rail follower, and the rail, then retighten.  Sometimes it only takes 1 shim sometimes more. On my D-15II, I used a busted hacksaw blade, on 1 clamp, after I ground off the teeth...Wink
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 7:25am
Some time back when the wife of just shy of 50 years asked if I would clean the oven while she went to her volunteer job, I said yes, so I went to the shop and brought the stuck assemblies to the kitchen, placed them on an old cookie sheet, placed in the oven and turned it on the clean mode, opened the outside door and watched TV.
When the clean operation was finished, so were the adjusters.
Edited by JoeO(CMO) - 21 Feb 2018 at 7:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 1:56pm
And WHAT happened to you Joe when she got home??!!
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 2:18pm
I used the wife's roster pot with s lid in the oven on clean that lid helps keep the smoke in the pan and not all over the inside of the oven. PS- PLEASE don't tell on me. lmao
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 4:53pm
Ted, when she returned the oven was clean and I never offered any more info.
She was pleased!
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 8:32pm
Hello again.  I know A.C. had  a tool that was used to loosen the eccentrics  pins.  What size was the head on the pin?  (3/4)? or something different. Thanks,  Steve
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 8:57pm
It was like a Budd wheel wrench, 2 piece, 2 different sockets on a piece of round stock, lug nut for the front, PA size for the rear.  Other piece was the handle, plain round stock, on one end it was crimped, to keep it from sliding out... some D series used same sizes, D-10, CA, used a 1/2" square instead of the 6 point 3/4 or 13/16, used on the bigger tractors. D-19, bigger still...Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 4:42am
A 3/4 socket fits too tight and if you try to use a 12pt. it'll probably strip or crack the socket.  Don't ask me how I know....  I think I used a 25/32 8pt. but it would still slip.  That was until I got them ALL CLEANED UP.
Once I got the eccentrics all cleaned up and LIGHTLY lubed, then the 25/32 worked fine.
You just HAVE to get them cleaned first.  Then it's easy.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 5:15am
The bolt heads , on the adjusters are a little rough in casting, supposed to be 3/4" but often needs a little filing, to get them there.  The AC wheel wrenches fit them just fine...
im4racin View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 7:21am
I use a 20mm 6pt sockets. I have one 1/2 and 3/4 drive. One to break loose and one for the stuff I have loosened up,
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 9:19am
I have had good luck with the 20 mm socket too. Have one I welded to a 1/2-3/4 adapter for the really stuck ones.
SLB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 1:03pm
Does anyone make the aftermarket wrench?
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2018 at 2:15pm
I use a 6 point 3/4 drive impact socket with 3/4 braker bar, fits tight sometimes have to tap on with hammer but is a good tight fit for tight ones
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 6:35am
Not that I've ever heard of.  Go into the classifieds section and put in a WTB (wanted to buy).  But to be honest, I think you'd be a lot happier to have a MM socket to do the job with.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2018 at 6:55am
I bought a 25/32 6-point socket. It fits all the ones that a 3/4 doesn't. Whatever you use, a 6 point is much better than a 12
This page was generated in 0.119 seconds.
