snap coupler blade
Hubnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Topic: snap coupler blade
    Posted: 09 Jan 2018 at 5:31pm
May be a stupid question, but.  Is the snap coupler blade for a B the same size as it would be for CA?  Just curious if it came in different sizes for different tractor HP.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:40pm
      Standard size of the snap coupler blade is 6 ft with extensions to make it 9 ft.   according to my owners manual for the  blade.
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 5:55pm
This is a picture of a blade that came with a CA.  The distance between the snap coupler hooks is 27 inches the same as the distance between the CA lift arms.  WD's and other tractors are about 31 inches between the tractor lift arms and I think the blades for those tractors would also be set at 31 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubnut Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:30pm
Larry, would that fit a B SC?
1940 B "Lucy"
1972 314H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 8:03pm
I don't have that blade any longer, but I think so.   As far as I know B CA D10 D12 implements would be the same.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 5:42am
I've never seen a B with a snap coupler.  This a home made rig, or an AC thing I've never heard of?
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 5:52am
No, the snap coupler set up was factory.  In our area snap coupler cultivator set ups are common and a lot a B's were retrofitted so the newer style two part cultivator could be used.  The full snap coupler hitch set up was less common, but in addition to the snap coupler lift arms a snap coupler bell was added.  To accommodate this the drawbar was reversed, the bell mounted to it and drawbar bar supports added.  A single larger ram, the same used on the CA, was also added.
Edited by Larry in NC - 10 Jan 2018 at 6:01am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:30am
I'd say you're right I've seen several B's with the snap coupler set up and they used the
same equipment as the CA (which was being built at the same time) and the D10,D12.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 6:36am
As a side note there used to be  an old AC dealer at Ekwood VA Chris Holmes that built AC  combination tractors to put Woods Mowers on.They mostly were a combination
of B,C,CA,D10 and D12 don't think any were ever exactly the same,some had a very nice 3pt on them.I see them show up sometimes at sales,they'll get people to scratching their heads as they were nicely done and used almost all factory AC parts very nice professional job.
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 11:54am
Some snap coupler blades have two holes in the cross strap to go from CA to WD.
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 12:51pm
You can drill the extra holes to narrow a WD45 blade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2018 at 12:57pm
Just extra one hole is needed
This page was generated in 0.042 seconds.
