Power Steering on D14,,,AGAIN,,,,!!! |
Page 12> |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13745 |
Topic: Power Steering on D14,,,AGAIN,,,,!!!Posted: 31 Dec 2017 at 5:27pm |
Well,,,,,,,,,,,,,,,,I had to use the D14 yesterday to raise some bundles of shingles to top of house for contractor,,,and the dang PS threw another fit and was not workin for chit. I hate havin to manhandle the dang steering wheel with BOTH hands especially in this cold weather. This POS PS has been on and off the whole time since I got the tractor goin. As some of ya'll might remember,,I milled the face of the pump to bring it to factory specs and replaced the two shafts that the gears ride on. I have had the pump off (heck of a job!) 3 times to verify everything. I even changed front tires to smooth thread in hopes of reducin the drag and run em at 50#. If you get any kind of load in bucket (4 bundles of shingles) it just will not hardly get out of it's own way.,and THAT is with both hands,,!! Has anybody managed to "Modify" this system to where it is a better workin system,,?? If it wasn't such a great tractor, otherwise,,I'd be pretty dang tempted to trade it for another brand or something,,,,,!!! (even a John Deere,,,!!!
MACK
Posted: 31 Dec 2017 at 6:23pm |
Have you checked pressure and flow of pump? Sounds like it is a pump problem. Is there any ware in center housing and gears?
What about control valve adjustment? Has it been adjusted and resealed? PS on these tractors are usually good. MACK |
desertjoe
Posted: 01 Jan 2018 at 11:52am |
Hey Mack,,many thanks for the comeback,,,A little history of my tractor,,, yes,,when I first started up the tractor after rebuildin the engine,,the PS became a big thorn. I did pull the pump and there was some wear on the shaft of the driven gear,,plus there was some wear on the matching faces of the pump. I had the pump faces milled to proper Gear/Pump ID clearances and built a new shaft on my lathe. I checked the output pressure at the control valve inlet and while I cannot remember exactly what the pressure was,,it was within factory specs,,(got it wrote down somewhere),,,The pressure ring on the ram had good end gap so I re-used it. Both gears inside the pedestal had good tooth contact and adjusted the rack as per book specs. I have cleaned and flushed the complete system TWICE thinkin some trash be floatin around. When I first started the rebuild,,the PS reservoir was plumb full of dry black sand lookin junk and I decided to completely disassemble the PS system and really think this crap was result of tractor settin for so many years. I believe I got all the junk out but maybe,,,??? The tractor as a whole showed very little use as it was purchased new by the Interior Dept for The Forest Service and stayed it's whole life at Fort Stanton up in the mountains til it sold at auction but was never rebuilt til I bought it from thet bidder. I have read where some farmers have used a Char-Lynn system mounted on the steering shaft,,,what do you think?? Also,,there was a member here that some time ago,,installed an additional pump above the alternator on a D15 that maybe a promise,,??? I KNOW farmers are the best inovators at makin do and modifyin their equipment to get the job done,,,,so,,,,How bout it all youse Guys,,,???
BillinAlberta
Joined: 12 Sep 2009 Location: Saskatchewan Points: 358 |
Posted: 01 Jan 2018 at 1:07pm |
I've had a bunch of experience with a d17 that acted like what you describe (I know there are some differences).But after rebuilding everything and nearly pulling my hair out I replaced 1 of the steel lines between the pump and the control valve with a hydraulic hose because there was a very small drip.
Surprisingly it smartened right up and has been great for 2 years now. Look for a minute leak. It sounds like the same thing as mine. Happy New Year!
dt1050
Joined: 05 Jul 2011 Location: central pa Points: 1078 |
Posted: 01 Jan 2018 at 2:45pm |
wow, have psteering my 1960 d14 and never had a problem, even with a loader bucket full of shale/dirt, still steers easy?
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34430 |
Posted: 01 Jan 2018 at 6:42pm |
Hey DJ, what kind of rims you got on the old tractor? Some car rims that stick out a foot or the origional style rim where they are under the verticle spindle shaft. Makes a huge difference on a non-PS D17...
MACK
Posted: 01 Jan 2018 at 10:34pm |
I would not go to the Char-Lynn.
Has the u joint been replaced or any thing been changed on steering shaft? Sounds like pump is weak (from wear or relief valve) or control valve needs resealed and adjusted. MACK |
desertjoe
Posted: 01 Jan 2018 at 11:10pm |
Hey JC,,,I'm pretty sure these are the original 16" wheels the tractor came with. Tractor is an Industrial Model D14 with the heavy Duty front axle. Also has the Shuttle Shift on left side with an oil cooler in the oil reservoir. Has two 3/8" metal lines that go to and from the Radiator. Just went and looked and they sit pretty close to right under the vertical spindles. Hey mack,,,as per my previous post,,I did rebuild the pump to factory specs and tested it on the tractor with an oil filled pressure gauge and discharge pressure was actually above the factory req'd pressure and RV did NOT open,,,,don't have any idea what the RV is set at but I did not mess with the setting and it did not bypass any. When I first started up tractor, I did not have the loader installed so I was not aware of any issues with the pump abilities,,,,,until I installed loader and tried to use the bucket,, I will mention one thing tho,,,,when filling the PS reservoir for first time,,I checked the two manuals I had and one said to use 20 Wt oil and one said ti use automatic Transmission oil,,,,,I opted to go with Dexron II,,,could that be the problem,,??? "IF,",,,"IF" the dang pump IS the culprit,,,what do you think bout an engine mounted pump similar to thet guy that did on a D15 for additional service connections at back of his tractor,,?? Soon as it warms up a little I will install the pressure gauge at control valve again just so I know what the heck is goin on,,,, What adjustments are you referring to on the control valve,,??? Many thanks for all your help on this for me.
Edited by desertjoe - 01 Jan 2018 at 11:12pm |
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 02 Jan 2018 at 5:59am |
Sounds like the control valve could have crud in it, causing it to stick.
"Burgie"
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24883 |
Posted: 02 Jan 2018 at 6:22am |
It's quite possible there's crud 'in the system'. Unless you cleaned EVERY part 3X, using fresh fluid each time(or refiltered) 'stuff' can still be there.You remachined the pump, so parts of it ground off and were 'in the system',probably for years. Even new hoses need to be cleaned. A sliver of cut hose end,just attached by one thread, can hold on then break off when oil flows a few times.
The PS on Milton here needs an overhaul but man there's a LOT of plumbing involved! Mine feels 'clunky',almost like you can 'feel' the steering gears moving.Have to admit it's nice having PS though I seldom use Milton. I'd probably remove and clean the control valve ,and flush the lines. I had to clean the CA pump 3X to get it right,spent 2 hrs looking for a check ball that rolled onto the floor...sigh that was 'fun',not! Jay |
MACK
Posted: 02 Jan 2018 at 8:35am |
The control valve has a adjusting nut that has to be set. Also Owings that needs replaced. MACK
desertjoe
Posted: 02 Jan 2018 at 9:28am |
UMMmm,,OK,,Thanks
JC-WI
Posted: 02 Jan 2018 at 9:31am |
I kinda have to agree with Burgie here, it should turn if you got good pressure and the fluid is getting to the cylinder...and there is only one thing in between... the control valve. ... unless the seal in the cylinder is leaking so bad.
desertjoe
Posted: 02 Jan 2018 at 9:45am |
Naw,,JC,,No external Leaks at all, The dang garage is colder than a well diggers arse (Sorry Les ) and I'm tryin to remember where I put up all the rebuild info on the D14 , so's I don't have to spend too much time in thet cold azzed garage. Not rememberin what the control valve looks like on the inside and ain't findin a cross section of it on the net either. Susspossed to warm up long bout Sat around here,,, ![]() How are you gettin along with this weather,,??
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 02 Jan 2018 at 5:09pm |
To get all of the crud out of the front casting, you need to take it off and disassemble. Wash it out with solvent. You will be surprised how much crud is in there. The only filter is a coarse screen on the pick up tube so it's to your pump and control valves benefit to wash it all out completely.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8734 |
Posted: 02 Jan 2018 at 10:50pm |
...sounds like Brian has your worst news/best case scenario.....fun,fun,fun!
desertjoe
Posted: 03 Jan 2018 at 4:06am |
Yeah,,Steve,,,and,,,,and,,,I was sure hopin NOBODY would even get close to suggestin I remove thet big, heavy, unhandy, unweildly, did I say HEAVY,,,center support,,,??? ![]() But,,,as a fact of the matter,,,I DID already remove it twice ,,,once when I first got the tractor and then again when I had to replace thet big pin that it swivels on the front axle. When doin the initial teardown,,is when I found all the old dried up oil residue in the reservoir, I had the whole thing completely apart and washed inside out real good. I disassembled the cylinder, control valve, both steering gears as I had to replace the btm oil seal on the output shaft. Everything looked and mike'ed out per specs so I lashed it all back up. After checkin the two manuals I had I filled with ATF and system worked with one finger turnin. At THAT point, I did not check pump discharge pressure as no reason to suspect, and loader had not been installed. Boy,,was I headed for a surprise,,,, After loader install is when trouble showed up. I then removed the friggin pump and fount the worn shaft on pump gears. Had the pump body milled and replaced the shaft. Then is when I installed a pressure gauge off pump discharge and pressure was within specs and RV did not relieve to bypass any oil. System was still IFFY, so I removed the pump 3 times, I think,, but discharge pressure was OK. Somewhere in thet time frame,,I removed the center support again to replace the big 1 1/8" pin and I flushed it out but system was very clean then. Removed cylinder and inside was also clean and ram sealing ring was ok, Mack mentioned something bout an adjustment on the control valve that I was not aware of ,,,and the more I think bout this,,,I'm thinkin that may be the culprit here,,,?? I remember some time back,,Dave Kamp talkin bout how the CV is susspossed to operate where something triggers it to supply oil to piston and then to bypass when toggled back and forth,,,,,HMMmmm Gonna see if I can find the thread I had when doin the rebuild of this tractor,,,,, ![]() Also, DrAllis mentioned on a D17 thread that current Universal Hydraulic oil was good for those PS systems and am wonderin if OK in the older D14 system,,??? Sorry for the long winded dis-a-tation,,but my arms still hurt from manhandlin thet steerin wheel 3 days ago,,,,, ![]() |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8756 |
Posted: 03 Jan 2018 at 7:53am |
Gee whizz, Joe, I feel bad for you. I certainly hope that you don't resort to replacing that tractor. You have your heart and soul poured into that thing. I sure hope that you find something simple wrong with it. Darrel
desertjoe
Posted: 05 Jan 2018 at 9:37am |
Well,,I had to use the loader on the d14 again yesterday and,,,AGAIN,,I had to fight the piss poor steerin on thet son of a gun,,!! I went ahead and set up the engine puller Gantry, chained up the loader to it and started to remove the Heavy pump guard and Radiator support,,,,and,,,,after lookin at everything that has to be removed to get to the control valve,,,,,I decided right quick that this is prolly a warmer weather job bein as it was 18°,,!! Gonna have to rig up a support for the engine as the front engine support has to be removed to get the valve out ,,,OR,,,remove the whole front assembly,,,!!!! Either way it is a BFG,,!! JEEEZE what a big job. SO,,,after readin some on other posts,,I dumped the ATF and filled the PS with Universal Hydraulic oil ,,,,and,,,dang if it did not work some better,,but without a load. Lashed everything back up and The real repair is gonna have to wait for warmer weather unless somebody comes over and builds a big shop sometime soon,,,, ![]() ![]() Many THANKS for all the suggestions and support,,,this shall resume long bout ,,,,,,,,April or May,,,,,
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11800 |
Posted: 05 Jan 2018 at 9:48am |
Getting back to basics, are you SURE you don’t have binding in the spindle pivots; or crappy thrust bearings?
Posted: 05 Jan 2018 at 11:28am |
gee 18 IS WARMER than the 5 I got here plus a big wind..., might say 'balmy'.
Have to echo what TG says..maybe raise wheels off ground and see if it's all free without any binding. Have to disconnect the tierods or whatever connects to the steering box. sorry names aren't good today..did I mention it's five frigid degrees here ! 73 days to Spring though !! Jay |
desertjoe
Posted: 05 Jan 2018 at 8:08pm |
Yeah,,Jay,,I used the loader to raise the front end and worked the steering wheel and "THATS how easy I want it to work",,
Everything was free with no load,,,I'm gonna wait for thet Balmy weather you talkin bout long bout April or may to tear it down again and fix it or trade it,,,,,,,![]() |
shameless dude
Posted: 05 Jan 2018 at 10:15pm |
trade it for a CHevy/Allis?
desertjoe
Posted: 06 Jan 2018 at 4:43am |
Shameless,,,Shameless,,,,Shameless,,,,,,,,,,sometimes you just leave me plumb speechless what with your most generous and thoughtful offers,,,,and,,,,and,,,you do that just cause you is such a kind hearted and thoughtful person,,,wait a minute,,,did I already say thet,,?? yep I did,,,,Chit,,,I am so overcome with your generousity my alcollades are runnin together,,,,,,,,, ![]() ![]() UMmmmm,,,when will you deliver,,,??? Do I got to sign anything,,,,??
will my loader and backhoe fit the WD,,??![]() Edited by desertjoe - 06 Jan 2018 at 4:44am |
shameless dude
Posted: 06 Jan 2018 at 6:41am |
maybe i'll dismantle it, throw it all inside a horse trailer and zoom on down, that way scales won't bother me!
Posted: 06 Jan 2018 at 6:51am |
DJ
you need to disconnect the wheels from the steering box, so NO power steering 'assist'. That means removing the tie rods at the axle stubs. You could have worn bushings that bind when weight is put on them and having the front end off the ground turning with PS won't show that. -7F here as I type...but 72 days til Spring ! Jay |
desertjoe
Posted: 20 Jan 2018 at 4:24am |
UMMmmmmm,,,well,,I got a bit of an update on the PS issue,,,altho it may not be the best option,,,,,the fact remains,,,,IT WORKS,,,!!!!! I took a few looks at the "massive job" to take the whole PS system apart to properly go thru everyrthing and check out all the different components and bein somewhat lazy these days,,,not even considerin how dang COLD it been these last two weeks,,,,I dumped the ATF out the system and re-filled with some THF,,,seein as how I wanted to go visit Ms Big Ones anyway,,,, ,,,and I couldn't believe my tired old arm muscles,,,!!! I mean,,it ain't one finger easy but I can now turn it (with some dirt in bucket) with just one hand,,,Gosh I'm so glad,,thinkin I'll prolly keep this old tractor now!! I wouldn't think the Hydraulic oil will harm the system so the teardown can wait till warmer weather,,,but,,,I'm sure wantin to leave it as is,,it works so good,,!!!
shameless dude
Posted: 20 Jan 2018 at 9:18am |
well....that saved me a trip!
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 20 Jan 2018 at 11:20am |
Aw Shameless, make the trip anyway,,,,,,,,,he's got sum beer to drink! An I'll be it's a LOT warmer down by him,.
desertjoe
Posted: 20 Jan 2018 at 9:03pm |
NO, NO, NO, Shameless,,,,I am bustin azz over here clearin a place in the boat shed for thet jewel,,,but,,,but,,,you didn't have to tear it down did ya,,?? That just means you'll have to hang around till I get it put back together seein as I might need some "guidance" on what goes where,,,,didya think to save all the bolts, screws, nuts Ya know for lashing it all back up,,,???
Listen to ole Ted Ok,,?? |
Page 12> |
